Question about Detto Technologies IntelliMover 3.0/ Transfer My PC (KT000IM30035PE01) for PC
Intelimover transfer I have the IntelliMover 3.0 and the USB cable but I only have one Monitor.. can I make the transfer with out a second monitor?
  • dd694 Aug 31, 2008
    Any help would be appreciated!
Do I need both cables for windows machine or can the USB connected to the machine and the mini dp plugged into the monitor work by itself
Is this an external monitor cable? Where the monitor cable that connects to the computer has two USB cables attached at one end?
If so, no. You do not need to plug both ends in. If one is powering the monitor fine and you see no performance problem occurring with the monitor you are OK to plug in just one.
The extra USB end connected to the cable is for additional power supply. If for some reason the machine you are plugging into does not supply enough power to the external monitor you would plug the second end it to the machine and boost the power to the monitor.
Hope that helps.
Oct 20, 2015 | Computers & Internet
On 3/13/05 I purchased IntelliMover version 3.6 after purchasing a PC with Windows XP system. Can I use the same equipment to transfer files,etc. from the XP to a new PC using Windows 8 or 8.1 ?...
Why don't you just put the hard drive from the XP computer into the PC you're using now. All your data will be there and you can delete all the windows files to gain that disk space back.
Aug 08, 2017 | Detto Technologies IntelliMover...
Why my usb docks no works in my monitor dell 1707 fpv
I have the same type of monitor and i use the monitor as a external monitor with my laptop. I have already done on my monitor the same thing that your trying to do. The solution to this problem is that the monitor itself needs a "USB 2.0 Data Cable -A- Male/B-Male" which one end of the cable will be connected to your desktop or laptop and the other end which is the around shape goes behind the monitor where the connectors are. I have added the picture of this cable. USB 2.0 Data Cable - A-Male/B-Male - 3 ft 9efce73d-dd31-46b9-97a0-7d3865632e38.jpg
Sep 16, 2013 | Dell Computers & Internet
Help Adding a 2nd Monitor to ALL-IN-ONE
Try using a VGA to VGA cable or a dvi to dvi cable because dvi-d and hdmi tend to lack the necessary pins to be converted to an analogue signal. A hdmi to dvi cable may also work
Jun 12, 2013 | Gateway One ZX4970G-UW308 All-In-One...
The 2 right (monitor's right) usb ports are not working, is there a fix
did you attach the usb cable from the computer to the monitor, needs this for powering the usb ports and to transfer data to the computer?
Dec 14, 2010 | Gateway FPD2275W LCD Monitor
I have an AOC 2236Vw monitor that is 3 1/2 months old. Just had to svc it under wty because display would go black a few seconds after power on. They did fix problem by replacing power board inside the...
I would call the support line and ask that they replace the entire monitor with a new one. If you have already had it serviced once, it may be a faulty monitor. Not too much else that you can do without coming out of pocket, which I am sure you do not want to do being that the monitor isn't even 6 mos old. Hope this helps out some, I know these things are a hassle but in the long run it would be to your benefit to have the monitor replaced while it is still under warranty.
Oct 17, 2010 | AOC 2236VW Monitor
How should i connect a monitor to dell inspiron 1300 laptop
Hi
Please follow these steps
1) Purchase a VGA cable (these can be purchased from any good PC shop)
2) Plug one end into the VGA connector on your laptop usually will have 15 pins sticking ut on the back of your laptop
3) Plug the other end into the Monitor
4) On your laptop press the fn key and F8 key (or the F key which has a picture of 2 monitors above it) - this will transfer the display from the laptop to the external monitor
5) enjoy :)
Please leave feedback/vote if my answer was helpful
Feb 12, 2010 | Dell Inspiron 1300 Notebook
Why don't my USB ports on my monitor work
1) good USB cable from Monitor USB input port to PC USB port?
2) Check pin 1 of the USB port, you should have 5vdc.
3) Your monitor's USB ports are basically the powered USB hub, but it must be connected to the PC USB port.
Jan 25, 2010 | Dell E176FP 17" LCD Monitor
Using a belkin easy transfer cable with only one monitor
Hi there. You can use the same monitor for boh the computer (just consider the annoyance of having to go to computer one, do the trick, disconnecting the monitor and connecting it to computer 2 and so on). If, what you want is to extract the files from the old pc because you are going to get rid of it and want to save them, I"d suggest you get a Hard Drive External Enclosure (between 20 and 35 dollars from most places). Connect such hard drive to it and read it via USB interface (or probably E-SATA or Firewire. Depending what do you have in your computer). Hope it helps, good luck.
Jan 05, 2010 | Belkin Easy-Transfer Cable for Windows XP...
A compaq TFT450, can it be used with USB to View?
no USB is not a video cable ever.
i guess you lost the manual, that it?
it tells you what the USB does.
page 2 tells you that is a USB hub, you use it to connect other USB devices, for say pc that has only 1 or 2 USB ports this allows more.
it is not related to VIDEO in any way.
Jun 03, 2017 | Compaq TFT450 14" LCD Monitor
Detto Technologies IntelliMover 3.0/ Transfer My PC (KT000IM30035PE01) for PC Logo
75 people viewed this question
Top Detto Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Detto Technologies Computer and Internet Expert? Answer questions, earn points and help others
