Did you check the outlet with a voltmeter? If you did and have 120Volts then it sounds like your latch switch could be defective which would kill the power to the unit.
But remember that in most houses that the outlet under the sink is wired for a garbage disposal where the top outlet is controled by a switch and the bottom one is wired for the dishwasher.
Testimonial: "Thank you for your help! I will check on that."
Are you sure the circuitbreaker is not tripped?
