Question about InFocus LP70+ Multimedia Projector
Infocus lite pro 720
Green dots on projector screen while playing movies started with green line down left side of screen now its like green pixals in picture
  • jasoncrossle Mar 01, 2009
    Vertical red line down center of image
Sounds like the LCD inside is dying and you're losing pixels. Bummer.
Posted on Sep 26, 2008
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
I have a white line going down the left side of my screen while playing a movie
Most likely the main board call TSC 1-888-942-2929
they probably have it. (not cheap)
Jul 26, 2010 | Optoma MovieTime DV10 Multimedia Projector
Infocus DP8400x blue hazey line
this discoloration is the begining of the lcd panel being thermal damaged. this happens when the projector is being used for a long period of time and then being shut off using the switch on the rear of the projector instead of the on/off on top or the remote. to fix it it will have to be replaced. very expensive major repair.
Jul 11, 2010 | InFocus DP8400X LCD Projector
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Line down left side of the screen
most likely a misconnection between the main board and the dmd board. if not that, you'll have to replace the main board.
Jan 01, 2010 | InFocus X1 Multimedia Projector
The start up screen is on with no signal through
Try a firmware upgrade.
http://www.infocus.com/Support/Products/Projectors/IN76.aspx
Oct 24, 2009 | InFocus Play Big IN76 Multimedia Projector
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Jul 03, 2009 | InFocus X1-RE Projector, Factory...
InFocus
Hi there
That is a definate Mainboard replacement.
Must warn you that it could turn out to be a expensive exercise
Feb 06, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP70+ Multimedia Projector Logo
962 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
