Question about Panasonic PT-47WX51 47" Rear Projection Television
Cleaning screen on my 1080i hd panasonic????
My two year old has put hand prints all over my screen and when the light hits it I can not see what is on the tv. How do I clean the screen???
  • 2,071 Answers
HOW TO CLEAN TV SCREEN;
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Posted on Aug 31, 2008
HD image doesn't fit in the screen.
Contact your cable operator and get the settings on Set top box adjusted. This will help you fit the image
Jan 01, 2014 | Samsung LN-T4071F 40 in. LCD HDTV
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
LCD TV has dark smears on picture
This not repairable,it a LCD screen have minor pixels cracks in the LCD screen itself,some body hit the LCD Screen with somethings.
Jan 12, 2010 | Panasonic VIERA TX-26LXD80 26 in. HD-Ready...
Tv does not turn on after the storm
It is most likely the power supply burnt out. The capacitor's inside are made cheaper than the o'l days and get overheated easily. You can test capacitors with capacitor tester and service manual. You can test power supply output voltage with just a voltmeter
Sep 10, 2009 | Televison & Video
Wii w/ 1080I tv
yes, you won't get the full 1080i HD experience, but it will work.
Aug 14, 2009 | Panasonic Televison & Video
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Refurbishing the 1080i-capable Panasonic 47-inch WS DLP
The tubes have a useful life of 3000 hours. Replacing those tubes is close to $3000.00. It's going to be cheaper to get a smart flatscreen TV. The minute you try to clean the mirror, you will put tiny scratches on it. There is no bulb in tour TV, There are 3 cathode ray tubes. There is a lot of high voltage (25,00 or more) inside the TV, so be careful poking around inside the TV.
Jul 11, 2017 | Panasonic PT-47WX49 47" Rear Projection...
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
1,797 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
