Question about Samsung Weather Resistant Security Camera SSC-12C
I got sound but no picture on my surveillance monitor
Can some one tell me how to fix this problem i got with the sound but no picture on the monitor. it's got good sound but no picture dose have a fuse or something i have to replace to get it working again or something
  • dh 1984 Aug 31, 2008
    never mind i got it fixed just had to refocus the screen
  • kaph3 Sep 19, 2008
    Monitor went bad on ssc-12b/w. Bought new system, plugged in cameras, have sound but no video. Plugged in camera that came with system, and same problem...sound but no video. Have refocused, but not the problem...any ideas on how to resolve issue?
  • 423 Answers
That cable might be bad. Try a different cable.
Posted on Feb 15, 2009
Will a HP 1740 monitor work?
you may choose another resolution in live monitor in DVR setting
Jan 21, 2016 | Zmodo 8 Channel H.264 Surveillance...
Is there a fix or do I replace the monitor? Thanks
You have 3 things to consider. The back up camera itself, The wiring and the monitor. Replacing the monitor may not be the fix. Hard to tell without considering the other areas.
Jun 17, 2014 | Winplus BT1326572 Wireless Vehicle Backup...
Checked connections, all good. Tested with another Winplus monitor, it works . The car battery was changed since then monitor has no picture but power button is on (blue). Menus not working either??????
If another monitor works in place, it sounds like you've found the culprit. If the other monitor works completely normally, and you aren't even seeing menus on that monitor, AND the power button is blue (which normally indicates powered and in use), it sounds like the back light or some internal connection on that monitor is bad. Hope that helps and good luck!
Intermittent picture on turn on - constant volume
Hi Ronni McClare,
For better assistance you can contact our Baby Monitors specialist.
http://www.motorolacordless.us/
Best Regards,
Katy
Motorola Support
Feb 24, 2014 | Motorola Mobility Mbp35bl Digital Video...
I have no picture on my monitor from cctv cameras
Try to check if the cameras are on. if they are on & the problem still persist please check the Coaxial or Cat 5 cable in other words your video cable.
Feb 05, 2013 | Home Security
L23Wd800 Monitor blinking cameras blue
Take it easy, change the tuner or the video chroma jungle.or check your connection, like some dual lens video recorder.it can solve it
Nov 06, 2012 | Lorex L23WD845 4-Camera Security System...
When I turn on the monitor for the two cameras I have set up It says that the frequency is out of range? What is the problem with this?
This is a simple fix
You simply need to turn down the resolution of the monitor
It is set too high to handle the picture and is a common issue.
You may also be able to turn it down from the settings option on the monitor or via the system itself
Mar 15, 2011 | Lorex New Lorex Lw2100 Digital Wireless...
The screen is blank on my baby video monitor it is white although sound can be heard the picture does not show please help..
the irus is not opening up. it is a camera prob. or the camera is just bad and can't transmit a pic.
Sep 26, 2009 | Home Security
Vertical lines on security camera
Sounds like a monitor that is on its way out....I would do a quick test and swap that monitor out with a different one and see it the vertical lines come back.....Let me know if this helps.....
cbinny1
Oct 22, 2008 | Home Security
Samsung Weather Resistant Security Camera SSC-12C Logo
162 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
bobby little
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
