Question about Saeco Royal Professional Espresso Machine
Small coffee and coffee not dispensing?
I have some issues with my Royal Professional Cappuccio.  Firstly, when pressing either the small or the normal coffee buttons no coffee actually comes out of the machine?  You can hear the machine grinding the beans, the prebrew message appears and the normal clicking sounds, also you actually see on the lcd screen the coffee cup filling up (although quite quicking?) but no coffee?  FYI, the large coffee function works well! What can be done to correct this? Please advise.
  • 1 more comment
  • rygar Sep 03, 2008
    Hi Mirran,
    You are a genius!! Thanks a couple of hundred of dollars!!!
    All the best and thanks again!
  • imlp Sep 20, 2008
    Same problem with the Saeco Royal Professional.
  • Anonymous Mar 17, 2014
    When selecting then pressing coffee button it starts to grind then when coffee is supposed to come out it just builds up pressure then there is a small bang and no coffee !! Just the round granule pod in dispenser
  • 515 Answers
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Posted on Aug 31, 2008
My Saeco Royal Professional says coffee beans empty although it is full
hi,
there is a small measuring device between the grinder and the brewer, that measures grind coffee flowing into the brewer. the brewer is the removable part on the right side of the machine.
it looks like that the measuring device is clocked or in worse case broken!.
my suggestion:
1.open the door on the right side
2. remove carefully the brewer/brew unit
3. clean it under warm running water
4. clean out the surrounding area, coffee pan etc.
5. check the measuring device for clocked coffee. it is square, has a small flap and easy to access with the door open. take a soft brush and clean the area, there might be a lot of ground coffee!
6. carefully re-insert the brewer acc. to manual, do not force in place.
7. close the door and use the unit.
you might also remove all beans and clean the burrs, the ground coffee outlet and check that it is free and not clocked as well. otherwise no ground-coffee will reach the measuring device!
good luck!
Sep 30, 2014 | Saeco Royal Professional Espresso Machine
Why wont the steamer work
hi,
he pump presses hot water through the grind not steam.
if the coffee is hot and hot water is dispensed, your line are clocked.
descale the machine as directed.
if coffee is cold the heat element is toasted. very unlikely though, since the machine will not dispens coffee, pump running if correct temperature is not reached.
good luck
Aug 08, 2014 | Saeco Royal Professional Espresso Machine
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
Coffee grind process completed but no coffee produced
inside the machine there is a small plate with alot of holes in it, it is the filter from where the beans get pressed, it can be stopped
Feb 10, 2013 | Saeco Royal Professional Espresso Machine
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
I have a Saeco Royal Professional at work and when each of the three coffee size buttons are pressed you get three different sized coffees. I have just bought a new Saeco Royal professional for home and...
Hi
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Apr 05, 2011 | Saeco Royal Professional Espresso Machine
How do I increase the amount of coffee dispensed on the large cofee setting. At present the amount is small
Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Sep 20, 2010 | Saeco Royal Professional Espresso Machine
Machine says ventilate
Hi
Push the water button. That is the one with the drop of water by it.
May 13, 2010 | Saeco Royal Professional Espresso Machine
Can't figure out how to retrieve the menu.
I have a Royal coffee Bar and to retrieve menue, hold down the button to the right of the small coffee button, if you look above the button you will see a line running upward to "ENT" above the small coffee button is "esc" and use the medium and large buttons for up or down arrows.
I ma not usre if it is the same setup, however from the pictures it looks identical except my machine has single boiler.
Mar 17, 2009 | Saeco Royal Professional Espresso Machine
After descaling the Saeco Royal Professional, all features remain functional except for the coffee dispensing. It will grind and the brew unit will go through its usual cycle, but no coffee will get...
The first descaling cycle likey dislodged some calcium which then found its way into a valve or water line. A second descaling cycle resolved the problem.
Oct 06, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
175 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
