Question about HP Deskjet 5440 InkJet Photo Printer
How do I check ink levels on a HP DeckJet 5440 in Windows 7? Printing a test page or trying to find it in properties do not work. These are the only solutions I've found online. Please help!
    Scholar:
  • 112 Answers
Hi there, You will need to install HP Solution Centre from your CD that you got with the Printer. That is the only way you can see ink levels. Below is a guide on how to install it from the CD. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02463264&lc=en&cc=us&dlc=en&product=445441#N741
Or you could try this option. Just download and install. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-90246-5&cc=us&dlc=en&lc=en&os=4062&product=445441&sw_lang=
Regards,
Posted on Jul 27, 2011
SOURCE:
Check ink level on hp deckjet F4185
Go through computer/printer properties.
Oct 01, 2013 | HP Toner for Deskjet F4185
My HP DESKJET 842C prints test page in Black and white only not in color, how do I test my Color cartridge is working or not?
try to do the : You can check the ink levels here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02693389&tmp_task=useCategory&cc=us&dlc=en&lang...
The driver for this printer, when used within Windows 7, is built-in or 'in-OS' so you do not have access to the HP solution center or HP Toolbox.
Printing the self-test report will show how the ink is dispensed and what levels of ink are available. If on this report there is nothing shown, the issue is likely related directly to the cartridges rather than a software issue.
If this is the case, visit this article and browser towards the bottom:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud02948&tmp_task=useCategory&cc=us&dlc=en&lang=...
There are steps on how to clean the cartridges as well as the underside of the carriage in case there is and debris or interferrance causing this issue.
Mar 23, 2013 | HP DeskJet 842c InkJet Printer
Is it possible to check ink levels on an HP C4345 All-In-One Printer/Fax. I use Windows 7. Have gone into Properties, etc w/no luck. Thank you.
First, I would try printing a document, and a window should pop up in the lower right corner. If not, make sure that you have all the necessary drivers for the printer installed, as that is the only way to check your ink levels with the HP C4345 All-in-One Printer. In my experience, you must use new HP printer cartridges (rather than ink refills) to have an accurate reading of the remaining ink.
Aug 11, 2011 | HP PhotoSmart C4345 AllInOne InkJet...
1. Will not print a PDF doc. but will print test page, and 2) how do I tell ink levels. No lights are on but it seems that the color cartridge is low. However, all the lights work when turning the printer...
check on the properties in the printer icon in your program file. open and see the details here to check.
If ink is low then replace by use the maintenance procedure.
set the properties for the document printing.
Sep 12, 2010 | HP DeskJet 6840 InkJet Printer
Hp photosmart c4580 (new) is not printing bottom line of page, also not printing centrally it misses words down the right hand side connected to advent windows vista can you help
Try printing a test page, if the problem appears there too, it could be a print head problem. But try a new ink cartridge first, to make sure that's not whats defective.
Since it's new, you should consider exchanging it while you can.
Sep 19, 2009 | HP Pavilion dv6000z Notebook
Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
Aug 03, 2009 | HP OfficeJet 4215 All-In-One InkJet...
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Slow Printing
Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
Sep 03, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP Deskjet 5440 InkJet Photo Printer Logo
111 people viewed this question
Clive
Clive
Thomas F. Schneider
