Question about Gateway 3550GZ Notebook
Replacing lcd I have a gateway 3550gz, the screen broke,, small hairline crack in screen, it eventually stopped working all together. I just got a replacement screen, we put it all together just like it was with the original, whaen the laptop starts up the screen is very dark, we mcan hardly msee whats on it. Is there a driver that needs to be downloaded? Why would it be dark like this and not start up like a new bright screen?
  • dezrtdevil Aug 31, 2008
    PEACEMAKER23
    The screen was a lcd 3550gz compatible, it looks identical. I tried the function keys and nothing happened. I have not reinstalled the video driver, I dont have any of the cd's that came with it 2 years ago. I took it apart again and made sure the 2 different areas that connect have good contact and they do. The computer boots up and does what its supposed to just the screen is really really dark. I can see whats on the screen but only at a certain angle and its very faint.
    BUNNYDAWG
    Lamps???
    Hmmm, When the screen originally broke I had it hooked to an external monitor...which I no longer have. When doing that does it make the screen faint like this? I pushed the function key to go back to laptop screen...it didnt work....?? Am I pushing the wrong button to make it go to original screen?
  • peace maker
    peace maker May 11, 2010
    did u replace it with the exact same screen???
    did u try to use the function keys to brighten the screen??
    did u try to reinstall the video drivers (cant be the issue but do it wont be harmful) ?
    Champion:
  • 200 Answers
My friend while i was thinking about ur situation in here this idea just passed by and it could be the reason why ur screen is so black
u know when u close the laptop (not turn off just close it) there is some kind of button maybe that one is always pushed down so ur screen is thinking that its closed so its always dark
just try to take a look at it maybe its jammed inside or there is smthing blocking it down
worth trying
cheers
Posted on Aug 31, 2008
    Brigadier General:
  • 5,158 Answers
Sounds like you left one connection off.... recheck the lamps
Robert
Hairlines and blotches on brand new Garmin Nuvi LCD screen
If your brand new Garmin GPS doesn't look good, return it for a replacement.
Jan 13, 2014 | Garmin nuvi GPS
Small Crack on the screen and the 58 inch plasma wont show picture but has sound can it be fixed?
The screen needs to be replaced if it is cracked, usually it is not economical to repair, but it is worth getting a quote.
Feb 28, 2011 | Samsung PN58B550 58 in. Plasma HDTV
Screen has white line that runs length of screen also has dark spots at bottom that looks like ink .
The white line is problem of the LCD's electronic. The spots are places where the liquid crystal is out of order of it's molecules, result of a shock and/or crack. Both problems cannot be fixed and the LCD screen have to be replaced. Take apart the lid and look the partnumber of the LCD on its back. Find replacement on ebay.
Aug 25, 2010 | Gateway NV5213u (LX.WDM0X.001) PC Notebook
Replacing laptop monitor. The new monitor
If it was not the right kind of LCD it may have blown the inverter (where the LCD connects and the cable going to the motherboard). You should order parts only from an authorized Gateway part reseller as advertised on the Gateway website. I have included a link to one such place below, where you can purchase a new inverter board and LCD screen if needed.
http://www.mundocorp.com/gateway-laptop-parts/m1628.html
Good Luck,
NOLA Tec
Jan 31, 2010 | Gateway M-1628 Notebook
KDL46W4100 no picture small white crack is visible when turned on. Crack got longer and eventually went across entire screen. People have told me the lcd is broken and it's not worth fixing - ie the part...
Yes, thats correct.
If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price.
New TV is better option.
Dec 16, 2009 | Televison & Video
Display problem
Has the phone been subjected to impact? What you are describing is 99% of the time caused by a hairline crack in the LCD panel - and the only way to fix it is to replace the display.
The hardest thing is getting the spare part - installing it is easy.
Jul 01, 2009 | Nokia N95 Cellular Phone
Broke i pod touch
If it is a first gen machine you HAVE to replace the front screen which I wouldnt do yourself as you are likely to damage the small ribbons holding the main boards together. So, you are better off taking it to a professional.
But I'm guessing from your description that you have a 2nd gen. This has the digitiser on the front glass. If the glass cracks then the digitiser becomes damaged.
Basically, you are not going to be able to fix it without spending money on it. The cracked touch screen needs to be replaced and then all will work fine. The screen for the 2nd gen can be bought fairly cheaply on eBay and is easier to fit yourself than on the 1st gen. There are videos on YouTube showing how to do it without wrecking the iPod.
Hope you get it fixed ok
All the best
Sean
Jan 13, 2009 | Apple iPod touch
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Broken Monitor
Hi Roeder, I have never heard of an LCD screen cracking from anything other than physical force, this is a first for me. It is possible since there is high voltage power in there for the backlight. In light of the sound I suspect a component failed, generated lots of heat real quick and caused the crack/failure. This is really unusual and you might try calling Gateway to see if they will replace it, especially if it is one year or less old. I would resist all temptation to open the LCD till you call Gateway. If they will replace it they won?t be happy to find you opened the case. Let us know how it works out and please don?t forget to rate this post.
Feb 02, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway 3550GZ Notebook Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
