Question about Electronics - Others
Pny memory stick
When I put my pny attache memory stick in the usb port my computer says it cannot be formatted. When it ofers to format it, the computer says it will erase everything on the stick i am trying to recover . what can i do?
  • 2 more comments
  • broncomw Sep 03, 2008
    I am trying to recover the information that I had stored on my memory stick. It says that by reformatting I will lose all information.
    Thanks
  • aex manu Jan 26, 2009
    just bought 8gb pny -attache flash drive and trying to use it on my macbook but couldnt find it on desktop or elsewhere to open it.....pls help
    just bought 8GB pny-attache flash drive and trying to open it on my macbook but couldnt find it on desktop or elsewhere to open it...help....new to mac
  • jordan king
    jordan king May 11, 2010
    hi,so what are you wanting to do exzactly??
    (formating will erase any curent data)
How do I format my pny Memory Stick?
Posted on Oct 05, 2008
  • 66 Answers
Once it is erased of your pen drive it is erased for ever
(you dont want to format it it will erase your date)
hope this helps :-)
Posted on Sep 04, 2008
Not recognized
It showed that the memory card has bad sectors try fixing it by typing "chkdsk x: /f /r" (x is the memory card) then press enter at the command prompt on your computer
Dec 28, 2013 | PNY Attach? 16GB USB 2.0 Flash Drive
Is the pny 16gb flash drive fat32 formatted?
click start click on my computer you should see your memory card
right click then select format
another way is to control panel administrive tools computer management disk management right click on your memory card or it might be listed as a mass storage device
select format
you will see what its formatted in
hope this helps
Jul 14, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
Computer says i have to format usb stick but if i do i lose my files
try application to rcover your files such as AnyReader or diskdigger
they are v good then format you flash
Feb 17, 2012 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
Jan 16, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
How to format memory stick Sandisk
Attach scansick memory stick to your computer
Double click on my computer
find your memory stick drive.
right click on the Memory Stick (MS) icon
choose format
click on quick format
click on start
click ok on warning appear
Aug 10, 2011 | Computers & Internet
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How do I delete the pictures from my PNY Attache 4G memory stick now that I have transferred them to another computer?
insert the card into your computer. The best way is (dependding what os you have...) open my computer in xp or computer on vista. Now right click on the drive your card is in now left click on format. It will ask you if will want to delete all the files click yes and your done it's been reformatted like it is a brand new card.
Warning once you format the card you can not undo what has been done so make sure you really want to delete your card.
Good luck and take many more pictures.
Oct 06, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
8gb PNY micro sd card isn't recognized in my samsung Alias
If the phone failed to format the SD card, try to format it through your computer. Connect the phone through the USB port located at the back of the tower. You'll be prompted that the PC detected 2 USB drives, the phone and the SD card. You will see it by going to My Computer folder. From there, right click the Letter drive represents the SD drive then select Format. I hope this helps.
Jun 16, 2009 | PNY 8GB Secure Digital High Capacity...
How to empty memor stick
right click on it and select "format"
then select "quick format"
then click okay
wait..wait..
it will tell you format complete
now its empty
Mar 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
May 27, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Electronics - Others Logo
303 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
