Color Wheel Replacement
In one of your articles I saw you offered to email pictures for the color wheel replacement procedure for a RCA DLP HD50LPW62. My email is warrenpolk@comfortkeepers.com if you can still do that. Thanks so much!! hampton630
  • 3 Answers
Hi Hampton,
Here is the link, email me if you have any questions. But a quick (I learned the hard way) hint is to go in from the front behind the screen. After removing the screws that hold it to the chasis you can quickly gain access to the color wheel, remove it's 4 screws and 2 connector cables and it is out.
Let me know if you have any questions.
http://www1.snapfish.com/share/p=991241224865368552/l=438844205/g=6447808/otsc=SYE/otsi=SALB
Posted on Oct 26, 2008
No Picture but sound
if you have a dlp with the 267888 color wheel, the wheels cant be replaced as RCA no longer makes them. If you use one of the other type color wheels you can get a replacement at the following link. They would need the model number of your set as The D52W19 isnt a dlp and doesnt have a color wheel. So just let them know what the model number of your set is.
http://servicemanuals.vstore.ca/
Jul 10, 2009 | RCA D52W19 52" Rear Projection Television
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
50" RCA DLP color wheel replacement procedure
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
Color wheel replacement.
Here is photo step by step replacement of color wheel.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Hope this helps
Oct 05, 2008 | Samsung HL-R5078W 50" HDTV
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
RCA DLP color wheel issue
The color wheel is a straight forward installation the indexing is where most people have the trouble as the color wheel needs to be indexed properly after instalation or the tints will be off. I always recomend that anyone needing to replace the color wheel go to this following link as they have the DLP service manuals which will help you get the set apart without harming anything and the site will provide free tech support to actually take you step by step with the replacement as well as the indexing proceedure by on line instant message and thats all free when you purchase the service manual which they email to you right after ordering. Is a very good deal as it makes the job easier and you will always have the manual and free tech support even for other models when you become one of their customers. Heres the link.
May 17, 2008 | Televison & Video
How to replace the color wheel on a RCA DLP
RCA DLP color wheel replacment is most efficiently done from the behind the screen, not the back panels where the guts of the DLP are located.
From there you do not need to remove anything but the color wheel and disconnect the two wires.
If you want to see pictures, email me and I can send you pictures. email: graphguy@gmail.com
Jan 18, 2008 | RCA HD61LPW165 61" Projection HDTV
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Electro Med Services...
