I have a Gateway FPD2275W monitor. When I turn on the computer the monitor flashes on for about 2 sec. and then seems to go into standby mode. Even the menu screens will not show up when this happens. When you remove the monitor cable and then plug it back in the screen will flash on for about another 2 sec. then go black again. any ideas?
  • TZKZDAD Aug 31, 2008
    Thanks for trying I plugged the monitor straight to wall outlet and two other outlets still no change.
    Scholar:
  • 152 Answers
Your power supply may not be supplying the required electricity to keep your monitor on. Try plugging your monitor in a different electricity source. Your CPU may be drawing much power from the source and not enough is supplied to the monitor. You may plug the monitor directly to the UPS (uninterrupted power supply) if the cable end allows it.
Posted on Aug 31, 2008
FPD2275w monitor monitor powers on but shuts off after 1 sec shows a picture perfect before it goes black all buttons light up and stay lit sounds like they r working
This model will likely have 2 or 3 bad capacitors in the power supply. You can see the tops bulging. They are 1000Uf @ 10 volts.
Monitor Mike
Aug 20, 2010 | Gateway FPD2275W LCD Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
My monitor fpd2275w gateway turns on but the screen is black
mine does it too...it seems to be that the back light is not staying on...seems to come on full brightness for about 3 seconds then goes out, there are images...but no backlight
Aug 27, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
All of a sudden the monitor resolution on my Gateway FPD1975W monitor is off. I am not given the option for 1440 x 900 as recommended. Icons are huge, screen saver is distorted. Was fine before.
Caller4 dance has the correct idea most likely the computer needs a video adapter driver installed or even an agp bridge depending on the OS and the motherboard type, it doesn't seem like a safe mode issue because windows restarts on Normal when it reboots in an error situation. let us know how it turns out.
Jan 18, 2009 | Gateway FPD2275W LCD Monitor
GATEWAY LCD MONITOR FPD1530. UNIT SHUTS OFF IN ONE SECOND WHEN TURNED ON, EVEN WITH XP SOFTWARE TURNED ON.
Hi...there,
It's seems your backlight inverter are busted... need to replaced a new one or repaired it.
Aug 21, 2008 | Gateway FPD2275W LCD Monitor
Monitor going to standby
Goto control panel > double click on power option to open it.now
now use these settings
Turn off monitor - Never.
Turn of hard disks - Never.
System standby - Never.
_______________________________________________________
It will be highly appreciated if you could take a minute and provide the feedback from the given below ratings
  • FixYa - The solution provides great advice on how to solve the problem.
  • Helpful - Helps solve the problem.
  • Thanks for Trying - Does not solve the problem.
  • Inappropriate - Nothing to do with the problem.
Jun 01, 2008 | Gateway FPD2275W LCD Monitor
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
