Question about JVC AV-32432 32" TV
Color there is no color on all channels but the menu page has color
  • 1 more comment
  • John Leonard Aug 31, 2008
    only the menu has color all channels do not have color the tv is hooked to cable.
    the d v player also has no color
    no color on any channel, the menu is in color only..
    there is no cable box used
    all video inputs are black & white.
    Genius:
  • 1,665 Answers
If your TV is multisystem select correct one (ntsc- secam pal... )
Posted on Aug 31, 2008
    Master:
  • 763 Answers
Check the settings of your tv. it must have been disconfigure or must change by somebody. contact your local cable operator.
cheers
CHARCOIS
  • 10,594 Answers
Your JVC Tv has problem with Color Processor circuit and you need qualified TV repair person to rectify and fix color problem.
  • Shahid Electronics
    Shahid Electronics Sep 01, 2008
    If your tv is multi color system, then select color system to NTSC 4.43MHz or 3.58MHz
    President:
  • 1,952 Answers
Ckeck then cable fault colour control panel so its some time ioose conect
    Brigadier General:
  • 5,158 Answers
If you are using an external digital box... make sure the tv is on the proper channel... usually 3 or 4.
Robert
    Sergeant:
  • 241 Answers
Check your Video Connections and if any go into the MENU and reset back to factory DEFAULT
This works most of the time
  • 1 more comment
  • Jayson Brollini
    Jayson Brollini Aug 31, 2008
    TRY to hook up a different device or try a different in-put like Video 2
    or S-Video
    Please Post for help
  • Jayson Brollini
    OK do you know what type of connection that you are using and did you read my comments
  • Jayson Brollini
    In your Tvs menu under the adjust the Picture Settings (press 0 button) to reset back to Factory Defalut
    > Are having NO COLOR on any channel or on the DVD. SO is it in BLACK and WHITE or no picture at all. I know you said the MENU screen is BLUE or in color ....Maybe if you unplug it from the wait 5 minutes and try again
    than make sure you have the correct video selected on the TV menu for the cable ( also make sure the TV signal is set fo Cable not Antena)
    Please Rate Your FixYa Expert-->Kindofcheap
  • 6,487 Answers
That can be a problem with your televisionsignal, if you want try t play a DVD and check if it will colore if it is definitley you can contact your cable provider if you have or adjust the antenna of your TV..
Hope that helps...........
  • Mark Gil
    Mark Gil Aug 31, 2008
    Did you try playing a VD and check if the view has color or still black and white?? just to check is the tv is really the prolem...
  • Mark Gil
    Try to reset if you have an option to reset on your menu pr power down the TV for about 2 hours thjat should reset it....
Toshiba 20A22 the kids took the color out of the
Don't try to reset it to factory. That will cause you more problems that will be harder to fix, especially with no remote. (Rhetorical question: Why do so very many people lose their TV remotes. How does that happen?)
Press the Volume Up and Down buttons at the same time. This will display the on screen menu. Release the buttons when the menu is displayed.
Now press the Vol Up button each time to advance the menu until the word 'PICTURE' is displayed. Press the 'CHANNEL down / ENTER' button to select this part of the menu.
Now press the Vol Up button each time to advance the menu until the word 'COLOR' is displayed. Press the 'CHANNEL down / ENTER' button to select this part of the menu.
To add color back, use the 'VOLUME up / Set+' key. To reduce the color, press the 'VOLUME down / Set-' key.
The user manual doesn't give a way to exit the menu, so my guess is that when left alone the TV will exit out of the menus itself on a timer. If not, try pressing Volume Up and Down together once more.
Sep 12, 2014 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
I just got a Toshiba HDTV 40RV525R and don't have a remote or owners manual. I have it set on channel 3, but don't know how to get any other channels? Can I move to another channel without a remote? ...
Yes you can if you have a signal hooked directly to the tvs antenna input. On the side of the tv you have some buttons including menu, volume which act as left and right while you're in a menu, channel which are up and down while in a menu. So, press menu and you should see a menu on the screen.Open the terrestial menu then input configuration and choose either cable or antenna to match what you connected to the tv. then select done to put that in memory. Open the menu aagin, go to set up then installation, then terrestial, then channel program and select start. The tv will start changing channels and will put in memory any channel it finds while searching. After this is done you can use the channel up and down buttons to scroll through all the channels.
Dec 05, 2009 | Toshiba 19LV505 DVD Player
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Color problem
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
Aug 01, 2008 | JVC AV-21meu 21" TV
Zenith tv model # H27H38DT
You can get the installation guide for a Zenith H27H38DT free at the following location. Look on page 36 to go into the VIDEO MENU and set PICTURE PREF to PRESET. That should restore the factory settings, so try that first. If you go into the actual Installer Menu on page 41, proceed with caution.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=cd7a9896391874248d179a4781a1ac71&q=Zenith+H27H38DT&e=1
Jul 26, 2008 | Televison & Video
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
No color on one channel
Some models of TV's can remember the user settings for each channel programed. Go in to the user menu for the video setup and see if the colour (chroma) is turned down.
Jerry G.
Jul 23, 2007 | Sanyo HT30744 TV
JVC AV-32432 32" TV Logo
113 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
