Question about Car Audio & Video
By pass the parking brake for the dvd player to work in my van
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 31, 2008
How to install my Alpine in my 2001 525I BMW also how to by-pass the wires that allow the DVD to work without the e-brake on.
to install it you need to buy a dash kit for your car from walmart or then you buy for your model and car the wire adapter kit. plain and simple from there. colored wires connected together easy as plug and play. to by pass the e-brake you need to buy a relay.
here is something i wrote up awhile ago for a buddy to bypass his after he took pictures of his model back.
On the back on the unit there should be an additional wire labeled as the "Parking Brake" or something to that effect. Law implies that this should be spliced into the Parking Brake wire (which is essentially a constant hot which becomes a ground when engaged). So the obvious thing here is to simply ground the Parking Brake wire on the back of the radio. This can be done just splicing it into the black wire on the radio harness.
found another solution from ehow for you
let me know if this helps
Mar 20, 2011 | Alpine INA-W900BT Car Video Player
How to by pass parking brake
Find the wire for the parking brake... Get a (interrupter) toggle switch. Ground one side of the switch to a grounding point in the vehicle close to where you are gonna have it. Hook the wire for the dvd up to the other side of switch....When you want to watch dvd, flip toggle switch...
Nov 11, 2010 | Clarion NZ409 Car DVD Player
Is the park signal wire supposed to be hooked to the ground side or power side of parking brake switch? I'm trying to install a kvt 512 for a buddy, and the dvd player wont work with out the park signal.
If you want to by-pass the parking brake wire, here's how.
Most wiring harnesses have a solid orage wire for illumination of the radio2_bing.gif and also have an orange wire with a white stripe for dimming purposes. Most radios do not use this dimming feature. Connect the brake wire to this wire and your able to watch your movies whenever you want. All the wire is looking for is a signal. It cannot differentiate between a parking brake signal and a non-parking brake signal.
Apr 13, 2010 | Kenwood KVT-512 Car DVD Player
I want to have the dvd player work while driving the car.
Kenwood simply requires grounding the parking brake wire.
Take the "safety" wire and ground it to your Head Unit Ground.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 05, 2009 | Kenwood DDX-512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
run a jumper to GROUND from that lead. it must remain shorted all the time you intend on watching the dvd player. With that said, I have one in my car that is hooked up that way and I put mine on a toggle switch so that, in the event I get pulled over I can hit the switch and it won't work unless I pull the brake. If you get caught wacthing a movie while moving, there is a fine associated with it! just letting you know. but its very kool to have it on long trips.
Mar 03, 2009 | Kenwood KVT-512 Car DVD Player
How to by-pass
Hello if you mean that you can't see the dvd screen while driving only in the park position with the hand brake on well, what i did i just connected the brake wire to a good ground source and it works great hope this answers you question HAPPY HOLIDAYS
Oct 04, 2008 | Farenheit TID-400 Car DVD Player
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
Car Audio & Video Logo
126 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
