Question about LG DLE9577 Electric Dryer
Very Hot Top
Our dryer gets very hot on the back top of the dryer just after seconds of being turned on. We are afraid to run the dryer. We had our vents cleaned but they were not able to finish cleaning them because of wet lint in the vents. We were told to run the dryer until the lint dries so they could finish cleaning the vents. Our dryer had died the morning we were getting our vents cleaned, so we could not test the vents or dry out the wet lint. We got or current dryer from our daugher-in law's grandmother. It has only been used for four months.
  • 706 Answers
It appears that your venting system is restrictive to a point that the hot air coming from the exhaust of the dryer cannot get outside due to excessive lint in the line. If possible, can you use a flex line and temporarily vent it out thru a window until your hard-piped vent dries out and can be cleaned properly? These dryers have thermal overloads to shut them down if they get too hot but since you mentioned the heat was near the top in the back.. I would make sure the power cord connections are tight.. ( do this by unplugging the dryer from the wall receptacle) the open the access cover were the cord enters the back of the drier.. then use a screwdriver and and make sure all 3 or 4 wire terminals are tight. A poor or loose contact there is resistive and may get hot enough to cause a fire. Make sure to remove or disable power BEFORE servicing this area.. Hope this helps..
Posted on Aug 31, 2008
Top of dryer and the back panel get too hot.
Of course they get hot, that is normal.
Jun 30, 2017 | Frigidaire AEQ6700FS Dryer
I replaced my thermal fuse on my pye2300ayw dryer now it gets to HOT
Whenever you change the thermal fuse the thermostat should also be changed...
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Maytag PYE2300AY Electric Dryer
Electric kenmore dryer #60702 is running too hot
the coil should glow visually through the of coil casing. if you reinstalled the rear panel,then watch the coil for the first 15 minutes to see if it still glows the whole time. if it does replace the snapstat sensor on the casing. also go outside and feel the heat coming out of the vent . it should be about 15 degrees cooler. the noise can be any of these; belt idler , belt , guides. ordryer not level. try these and get back to me please. thanks karl
Oct 31, 2009 | Kenmore Dryers
I turn my dryer on and it immediately gets hot on the top of the dryer. So hot you would get a 2nd degree burn if you touched it. Then you can start smelling a burning smell. I've checked outside to make...
If this is as you say, please contact your appliance dealer as soon as you can. You are right, don't use it. You dont' want to be seriously injured nor injury someone else and as for your place catching fire, not a remote possibility.
Sep 21, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I just went to use my Kenmore electric dryer, model no. 110.64622300, & found 3 problems: First, the light was not on with the door open, so I put in only part of my laundry to make sure it was...
OK, the door switch has either failed and isn't working properly or has been pushed out (broken) from it's proper mounting position. Many older dryers will run with the door open, as long as the timer is running, so not to worry about that issue.
As far as the dryer seeming to be very hot, it's normal for a dryer to get hot rather quickly to dry clothes. But, with that being said, check the entire exhaust pipe to make sure you don't have any blockage that might be causing a venting problem - you want the vent pipe clear and clean and it should be checked at least once a year to make sure you aren't getting a builidup of lint, which could lead to problems with the dryer, or worse, a potential fire.
Now, onto the door switch. If you open the dryer door, you should be able to see if the push button switch is present, or has been broken or pushed into the dryer cabinet. If it has, you'll need to replace it with a new one.
The switch you need is Part #3406107 and should be under $20. It is fairly easy to remove and replace.
First, turn off the breaker to the dryer and/or unplug it from the power outlet. Then you can remove the top panel, by using a small, sturdy plastic or metal putty knive topush in the retaining clips that hold the top to the main cabinet.
Get down and look at the edge under the top (about an inch from the top surface) and there should be (2) indents near each side of the top that you'll use the putty knive to push in the retaining clips to release the top. Once both are released, you can tip up the top and get at the door switch.
Once you've done that, you can remove the faulty door switch and unplug the connector and put in the new switch and put everything back together.
Here's a line drawing that shows your dryer and the parts list (with the switch you need) to help you with the process.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11064622300&productCategoryId=0151200&brandId=0582&modelName=ELECTRIC-DRYER&diagramPageId=00002&componentDescription=CABINET&documentId=P0303082&backToLink=Return%20to%20Sub%20Components%20list
This will save you quite a bit of money, versus having a service tech come out to do this rather simple repair.
Hope you find this Very Helpful and best regards!
Sep 16, 2009 | Dryers
Electric Dryer run too hot
wow, dont get burned, check your ventillation, make sure your vent is not clogged or smashed, if this continues, then change out your thermastat
Aug 16, 2009 | Frigidaire FDE647RF Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Very very hot
i would say the heat senser is not oicking up the right temp. you should have a tec. check it out and not run it until they look at it a dryer can catch fire quickly. please be safe.........
Jan 04, 2009 | Frigidaire FGR341AC Electric Dryer
LG DLE9577 Electric Dryer Logo
182 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
