Canon EOS-20D Body only Digital Camera
Problem for Canon EOS-20D Body only Digital Camera
Canon EOS Digital Rebel XTI
By bsgra on Aug 31, 2008
Canon EOS Digital Rebel XTI 400D
Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99
camera is totally charges, acts dead, keep flashing Err CF, I try to format, it then says busy and gives me an Err 99. Please help! I'm lost w/o my camera!
Solution #1
posted on Aug 31, 2008
Not Rated)
coolguy008
Rank: Wiz
Rating: 83%, 603 votes
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Solution #2
Not Rated)
marked
Rank: Guru  Canon Expert
Rating: 86%, 964 votes
Normally it can be an assortment of things:
Dirty contacts between lens and mount causing a glitch in the communication.
Use of outdated or obsolete chipsets on certain lenses
Jam in the motor
I/O error on the cf card
Mechanical failure
Most of the time its a bad contact with the lens and the mount. Try cleaning it with a q-tip to wipe residue off the metal contacts.
Hope that helps.........
Solution #3
Not Rated)
Kindofcheap
Rank: Wiz
Rating: 80%, 76 votes
http://www.canon.co.jp/imaging/eosdigital3/e4kr3_firmware-e.html
This a firmware problem here look how to fix it here
Comments:
Aug 31, 2008
- I had a camera do that same thing to me but different model
I sure hope that this helps please post more comments
Please Rate Your FixYa Expert -->Kindofcheap
Popular Solutions for Canon EOS-20D Body only
Questions and Unsolved Problems for Canon EOS-20D Body only
Do you recommend Canon EOS-20D Body only Digital Camera?
Answer
Answer
canon eos20d turns on . av flashs in the led screen an will not do any thing else.
Answer
My LCD screen needs to be replaced. The door to to the battery chamber needs to be replaced.
Answer
canon 20d power comes on but wont fire and menu wont come on rear screen
Answer
i have a canon eos 20D and the camera don`t accept 2, 4, 8 GB CF i download the last actualization... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
