Question about Olympus Camedia C-5050 Zoom Digital Camera
Memory card compatibility
I would like to upgrade memory on my C5050. I fancy Compact Flash memory cards of 1,2 and 4 GB. However, I was told that I have to check compatibility of such cards. Olympus tech support says that I should check compatibility issue with manufacturer of specific card. Contacting competent people of memory manufacturers seems to be extremely difficult. Would anyone else have some experience with this?
  • Anonymous Mar 22, 2014
    when I insert the compact flash memory card the door will not shut
    Master:
  • 852 Answers
For what it's worth, I know it's not advised to use cards higher than 512kb in an Olympus E-10. I don't know if Olympus have used the same 'card' technology in both cameras, though.
Posted on Sep 12, 2005
    Master:
  • 852 Answers
Can't be much help on this one I'm afraid. I too have a C5050 and have numerous cards the largest of which is 512MB. I wouldn't like to use anything bigger than this just in case the card fails. I don't like having all my eggs in one basket. I quite often change cards on a shoot well before they are full also for the same reason. . Not so expensive to replace as well when they do go wrong. I also have an XD card loaded at the same time and swap between the two frequently That said to date I haven't had a CF or XD card fail on me as yet, but theres always a first time. I've also never had any problems with the C5050 recognising any CF cards of any type up to 512MB in size and cannot see any reason why they would fail to use a 1GB or above.
I bought a 2 gb compact flash card. Are these not
It appears that the 9700 works with Type II CFD's.
I think that the 2 Gb cards are ULTRA II's which likely will not work with your 9700. The 512's are getting harder to find as well...
Nov 10, 2009 | Janome Memory Craft 9000 Computerized...
I have Sandisk Extreme III 4GB memory card why after i shooting photo the file is cannot read?
Make sure your camera is compatible with a 4GB flash card. Some only take 1 or 2 GB cards. If that isn't the issue, format your card inside the camera with the camera's format utility.
Oct 08, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Suitable compact disk memory card for dimage a200
I have the same camera. It will use up to a 4GB card as standard and up to 8GB with the correct firmware.
Check the following web address for further information: -
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-a/dimage-a200/software_drivers/firmware/installation_guide.html
I hope you find that my answer has helped, if so please return the favour by rating my answer.
Jul 21, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Using bigger than 64 MB compact Flash Cards
I have the same machine and if you watch the dvd included with the machine it says to use a MC no bigger than 1 gb. I use a 512mb and it works fine. Your computer may not have a MC port so you will have to purchase a memory card reader which you can purchase on ebay or at Fry's for around 10 dollars. All the files need to be saved on the MC card as a SEW or JEF file. When you go to your machine touch the emb. key then the disc key and you should see your files. You may also need to turn the page; sometimes it save it on different pages.
Apr 12, 2009 | Janome Memory Craft 9000 Computerized...
New memory card and the camera says its full
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
EPSON RX600 PRINTER
Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
Please use this chart as a general guide line.
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
Compact Flash 4 GB
Secure Digital 1 GB
Sony Memory Stick 1 GB
MagicGate Memory Stick 128 MB
xD Picture Card 512 MB
Smart Media 128 MB
Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
sorry for this one :(
Apr 18, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Incompatiblity of R300 & Toshiba 2 GB SD Memory Card
Epson Printers & All-In-Ones:
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED Compact Flash 4 GB Secure Digital 1 GB Sony Memory Stick 1 GB MagicGate Memory Stick 128 MB xD Picture Card 512 MB Smart Media 128 MB
These are the Epson tested memory cards that will work, also includes the suported memo capacity..
Hope this is helpful, pls dont forget to rate solution.
Apr 08, 2008 | Epson Stylus Photo R300 InkJet Printer
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Sep 08, 2005 | Toshiba e800 Pocket PC
Olympus Camedia C-5050 Zoom Digital Camera Logo
148 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
