Canon PIXMA  MP160 All-In-One InkJet Printer
Problem for Canon PIXMA MP160 All-In-One InkJet Printer
Error 300 , problems printing
By mmmrk on Aug 31, 2008
hi,
I'm hoping you can help me out with the problem I'm having printing off my MP160.
I'm getting this message when I try to print :
Error number : 300.  The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
The on/off lamp in the corner is on and the computer seems to be properly connected from the back port of the printer to the USB port on my Mac.
So what else could it be?
I've been able to use this printer before without any problems, now I'm suddenly unable to print!
Please help if you can!
Thank you!
Mark
marklukac247@gmail.com
Same Problem
Oct 19, 2008
-   my printer suddenly stop performing all the work ..as scanning and printing. it was working good and after an hour it does not repond to our command.it just take the paper in and the output is blank,i checked the ink level and all the wires connect to the printer.. i am confuse ..please help me out.-   rinjee
Oct 17, 2008
-   MY printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. -   jesder
Oct 08, 2008
-   ik kan niet meer printen sinds ik de inktcartrige heb vervangen. Ik krijg een melding dat de printer niet is aangesloten (op de computer als ik wil afdruken). Dit heb ik nagekeken de stekkers zitten allemaal goed. "Communicatie met de printer is niet mogelijk."
Ik heb alleen de cartridge vervangen meer niet-   Guest
Solution #1
posted on Sep 06, 2008
Somewhat Helpful)
gutspiller
Rank: Master
Rating: 80%, 3 votes
According to my list error E 300 means servicing required. how much that would be is anyone's guess.
Was this helpful?
Yes
No
Solution #2
posted on Mar 16, 2009
Not Rated)
ksdi
Rank: Wiz
Rating: 82%, 29 votes
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
282
Was this helpful?
Yes
No
Solution #3
posted on Oct 08, 2008
Not Rated)
namikis
Rank: Apprentice
Rating: 0%, 0 votes
This problem drove me nuts for an entire day - neither my Mac nor my Windows machine would print after resetting the ink levels using MPTools. I kept trying things until, as a last resort, I decided to reinstall the drivers (which did not seem to me like it would do anything as the printer was working fine before in the two machines with the existing drivers) Voila, that fixed it. I had to reinstall the OS X and the Windows drivers. In the Windows side I had to delete the existing printer drivers first, then reboot. On reboot Windows discovered the printer and reinstalled the driver. It started working again.
It may be that driver re-installation clear certain caches in memory - only Canon knows.
Next time I am getting an HP printer.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP160 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP160 All-In-One
Do you recommend Canon PIXMA MP160 All-In-One InkJet Printer?
Answer
Answer
Printer displays Error Code 4 and 2 when ink cartridges are replaced
Answer
My canon mp160 show alarm & dose not work pls solve my problem?
Answer
MP160. Will not print. Error message, remove paper jam and push start button. there is no jam and... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , IL
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
