Question about Whirlpool Duet GHW9150P Front Load Washer
Replacement baffle installation
Thank you for helping me replace the baffles in my washer. I thought I had to pull the guts out to get at the screws. You are the best! Stephen
stephenm38@hotmail.com
  • rondal62 Sep 30, 2008
    Baffle is broken on GHW9100LW. How do I replace it?
  • 1,031 Answers
Thats why we are here,thanks for the compliment
Posted on Sep 03, 2008
Baffles broke in front loading washer
You will need the screws to hold them in and unfortunatly to do them you have to split the 2 drums apart unless you can see where the screws mount on the new baffles, but usually they screw in from the outer side of the inner drum. A lot of work for such a small part.
Dec 29, 2012 | Kenmore Washing Machines
F & 5 flashing, clothes not drained
don' t remove back!  top comes off and drum can be spun  to access each of impellers in drum.
Jul 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replacing a part on a Kenmore Washer HE 3T
you shouldn't have to get from the backside the screw is at the rear of the baffle once you remove the screw the tabs slide and lock into slots push and pull and just reverse the process when installing the new one
Sep 03, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Baffles in washer
the new baffles arefairly easy to install, they go over the hole and then pull foward to lock into place.. the new bsaffle should also come with a screw to "lock" it, in place. in order to securethis screw you need to remove the top cover of the unit,(3 screws across theback) after removing the top youll see a black hose going directly into thetop of the tub prbably an inch or so . gently pull that hose out from thetub. It simply locks itself inplace.. after removing you can spin the inner drum around till thenew baffle is directly under the "hole" where you can now see a small hole inth eunderside of baffle to secure.. just remember to resecure that hose or youll have a flood on your hands
Mar 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace whirlpool duet GHW9200LW baffles
easy repair, they simply slide over hte slits in the tib and firmly pull forard to snap/lock into place. there should also be a screw included in the kit, remove the top of washer (3 screws across the back of the lid)after removing hte main top toull see a black accordian like hose leading to the top of the tub assy, from the dispensor box to the left. remove this hose from the tub( pulls out of the hole), then simply turn the tub form the inside till the baffle you installed is at the 12 o'clock positon your screw hole will be right there. RESECURE THE HOSE, reassemble the top and your done!
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Aug 09, 2008 | Washing Machines
Kenmore 40922 front load
This advice from Sears to replace baffles only applies to dryers. The baffles for the washer are installed from inside the basket. If you can't locate mounting from inside the basket, then the entire basket/tub will have to be removed and disassembled.(big job)... But I am pretty sure they mount from inside. Washer or dryer, there are three screws in the rear along the top. Remove screws, slide top toward rear and lift off.
Jun 07, 2008 | Kenmore 4292x Front Load Washer
its a little tricky but can be done. Can you remove the top panel of your washer?? 3 screws along the back lip and the entire top will slide back and off. theres a little black hose leading from the soap dispensor to the top of the outer tub assy. its only pushed into the tub and is real flexible, pull it out .you see through the maybe 2inch hole and see he inner basket. as you rotate the basket from inside with your hand the inner baffle(s) will line up to the hole and depending on date of manufacture. they might have put a small stainless screws in from behind to hold baffle in place,ifso remve the screws and the baffle (although a little tricky should slide toward the rear of machine to remove, and pull toward the front to reinstall
Mar 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Coin stuck in the tub baffle
on top of the machine where the filter is there are 2 screws`remove.gently pry up on the top front of machine.it should pop up. rotate tub till your coin gets to the top .you should see the screws you need to remove .
Feb 24, 2008 | Kenmore Elite HE4 Electric Dryer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
356 people viewed this question
Dan Webster
Dan Webster
Sal De
