Pioneer PD-M603 6-Disc CD Changer Logo
Anonymous Posted on Jul 27, 2011
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after another and does not play them, what ever I do Thanks for help
  • Anonymous Jul 27, 2011
    first used a dvd cleaner disc. It didnt work. Then I opened the cover, - and out fell first one half of the lens, then the other half. It as broken. I loosed the detailjs that it was fastened to and found the hole where it shall sit empty. It did not work to fix it. Can I buy this lens or this part that contains the lens and shift the old from a new one? Where can I buy it? Regards and thanks
pb245
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 04, 2012
pb245
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2317
Points
5
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Anonymous
Level 3:
  • Master 1,961 Answers
  • Posted on Jul 27, 2011
Anonymous
Master
Level 3:
Answers
1961
Questions
Helped
665638
Points
5692
The lens of your player needs to be clean .you can use a cleaning disk.or you can manually clean it by opening the cover then use a cotton buds moistened with an alcohol .gently wipe it on the top of the lens until dust are remove.
  • 3 more comments
    Thaank you!!!
    But How do I know what is what when I open this lid on the disc tray. How can I recognice the lens. Must I take of the Outer cover?
    Thanks?
    I first used a dvd cleaner disc. It didnt work. Then I opened the cover, - and out fell first one half of the lens, then the other half. It as broken. I loosed the detailjs that it was fastened to and found the hole where it shall sit empty. It did not work to fix it.
    Where can I buy it?
    Regards and thanks
  • Anonymous Jul 28, 2011
    yes you can buy a replacement lens the part number is written on the surface of the lens sticker.bring your old lens as sample when buying a new one.
    Is there any thing to think about when apply it again, - shall i use glue?
    no sir you need to replace the lens with a new one...
I have my late husband's Pioneer PDF906, (100 disc capacity) and I created eleven music CDs on my computer which play perfectly in my computer, my car and my DVD player, but with the PDF906, only the...
The last 3 discs might be CD-RW which can be rewritten, but not all cd players will be able to read them. Just go to the store and buy some CD-R disks and re-burn the last 3 disks. That should solve your problem.
2helpful
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
My Pioneer PD-M403 will not play computer made CDs. Why won't they play?
incompatibility is the cause of the problem. There is nothing wrong with both your player and the computer made CD's, they are not just clicking with each other.
The Pioneer PD-M403 player is also an old model, this could cause the problem.
There is not settings whatsoever that you can use ti solve this problem.
Take care.
2helpful
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
3helpful
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
My Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
2answers
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
1helpful
2answers
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
