Question about Janome Memory Craft 4000 Sewing Machine
Machine does not power up
The machine was working and then it had no power to it. I have taken the switch apart and there is power to the switch and the switch does work. Have been hesitant to take the machine further apart. But it does have power to the machine and throught the switch. HELP!
    Genius:
  • 3,422 Answers
The fuse is located in a little black box underneath the base of the machine, but it is not an easy job to take the box out, disassemble it, replace the fuse, and then reassemble the whole machine. I suggest you take it to a service center.
Posted on Aug 31, 2008
The RCS Unit powers on but I cannot use any functions. When you press the buttons, nothing happens
Inside the machine there are many parts that have wires connected together. If one of them have been taken apart by accidental bumping it may cause this. By carefully opening up the machine and looking you may see the problem. However, touch yourself to some metal before messing with it. It is a better idea to let a pro take care of it.
Jun 28, 2016 | Janome MB4 Four Needle Embroidery Machine
Is it possible to change the fuse in a sewing machine?
the only fuses ive ever seen inside a sewing machine was located inside the foot switch assembly and ive taken apart a few dozen now , but now ive seen quite a few broken power cords and sockets in that few dozen , seems the power cords sure take a beating on these ?
Jan 14, 2016 | Sewing Machines
Light bulb
My brother LS 1217 sewing machine under thread is very loose. I tried all options like adjusting the wheels, tension, rethreading and played with the machine. No use.
Jun 15, 2013 | Singer 7462 Mechanical Sewing Machine
Brother CS-6000 E1 error message - my presser foot is not up!
Did you take this machine apart? If so, then the lever that extends from the thread tension wheel is to the right of the raised presser foot switch plate (inside the sewing machine), keeping the switch from being unpressed.
Take the machine apart again, raise the presser foot, and put the machine back together. This will ensure proper alignment of the plates.
Jun 25, 2009 | Brother CS-6000
Janome 9000 won't turn on
The machine does not run.
1 A thread is caught in the hook race.
2 The control circuit is not working correctly. Turn the switch off and
turn it on again.
3 The machine is not connected to the power supply.
(I know duhh...but maybe your plug into the machine itself was loosened during your repairs.
Go to Janome.com and ask the professional Ask Jan, if none of these solutions work.
Hope this helps
Jan 24, 2009 | Yamata FY14U4AD
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Janome 7000
there is a little switch at the back behind the needle. I had the same problem and after i wiggled this switch it s now working. Hurrah!
Jan 10, 2008 | Janome Memory Craft 5700
19606 sewing machine
Find a local dealer who sells Janome. This machine and most Kenmore's are made by Janome. However I know theyb will charge $80 or so to ven lok at it. I have this same machine also refurbished and no big issues as yet except buttonholer foot was broken when I got it. Am still awaiting a new one a month later.
Dec 30, 2007 | Kenmore 19606 Computerized Sewing Machine
Machine foot will not work
Have you taken the foot control apart yet? What have you got to lose. Possibly something came loose that you can put back in place? There are small carbon contacts that may be put back in place. Just remember to put it back togeather the same way you took it apart. Or keep an eye on eBay and ask questions. Mostlikely a generic footcontrol will work. Good luck. Rick
Aug 20, 2007 | PfaFF Tiptronic 2040
Sewing Machines Logo
253 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
