Samsung HL-S6187W 61 in. HDTV black screen on the right side
Your comment:
Ifyou found a bloated capacitor on the circuit board, that one needs tobe replaced not the board. You can see the part number on the capacitoritself. Also please look for any burned IC and neighboring components.If you found additional burned components, it also need to be replace.Contact a pro tv technician to replace it.
I am not seeing any sign of bloated capacitor on this and any other circuit board.
See picture at:
http://client.fineaperture.com/p/samsung_hl-s6187w/_dsc44064
  • 4,234 Answers
I don't have your original problem here, so I can only comment based upon the info in this question. I assume that the set does not start or clicks like it is goimg to startup but then shuts down. If this is the case, there could be a number of issues causing this. The set has a number of protection circuits that will shut down the set if a problem is detected. This may or may not be a power problem. The best way to resolve this is to repost the original problem so those of us with TV repair experience can assist you in resolving the problem.
Thanks,
Dan
Posted on Sep 04, 2008
    Genius:
  • 1,269 Answers
Looks like the transformer's secondary winding is burned. The one with part number 35B020-NY. Better have it checked by a TV technician.
Posted on Aug 31, 2008
I have a samsung hl-s6187w 61 inch and it keep shutting off.. the screen goes black but i still have sound for about 5 sec then shuts off.. can anyone tell me what the problem is?
Sounds like fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 16, 2015 | Samsung HL-S6187W 61 in. HDTV
There's a bloated capacitor on the circuit board. That one needs to be replaced.
Aug 30, 2008 | Samsung HL-S6187W 61 in. HDTV
I doubt it's the color wheel. When our wheel went bad the TV didn't come on at all. It could be the lamp. Try reseating it first. That fixed a problem the first time for us. Later we had to replace the lamp because the TV was getting dark. It could also be your ballast, but we've never had to change that. I'd start with the lamp.
Samsung HL-S6187W no picture, no sound, no start up jingle... Lamp is on, can hear color wheel turning. Already tried new lamp, new dmd chip, and new dmd board... Now what?
I have had issues where the digital board and also the analog board have been known to cause weird symptoms like that. Did the picture ever freeze any time before this isuue appear?
Oct 20, 2012 | Samsung HL-S6187W 61 in. HDTV
My samsung hl-s6187w keeps shutting off. after 10-15 seconds
I would suggest looking over the power supply for bulging capacitors. Had the same issue and the power supply needed to be changed.
Sep 11, 2012 | Samsung HL-R6167W 61" HDTV
Samsung dlp hl-s6187w turns itself off after about an hour of operation. Once it cools down (5 minutes) it can be turned back on. what could be problem
check or replaced LAMP-BALLAST board
Manufacturer Samsung Part Number BP47-00037A Description LAMP-BALLAST;EUC 132
Nov 09, 2009 | Samsung HL-S6187W 61 in. HDTV
If you found a bloated capacitor on the circuit board, that one needs to be replaced not the board. You can see the part number on the capacitor itself. Also please look for any burned IC and neighboring components. If you found additional burned components, it also need to be replace. Contact a pro tv technician to replace it.
Order parts here:
http://www.partstore.com/Sitemap/Generic/Television+parts/Television/Television+parts/television+parts.aspx
Cracked screen
Outside Viewing Screen with Grooves: This is a lenticular screen used exclusively with CRT
the Fresnel-lenticular screen would be a non-glare surface with vertical ribs, as shown here:
http://www.highdefforum.com/gallery/data/511/40Optawave-Diagram.jpg
Jan 10, 2008 | Samsung HL-S6187W 61 in. HDTV
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
Electro Med Services...
