Hello
You can unlock your blackberry 8700g online now within no time from Blackberry unlocking codes with IMEI. They are very trusted, safe and offer CHEAPER packages for their customers with great customer service.Once you get your phone unlocked from them, you can carry it easily to different countries without any problem as well.
I hope that would help.
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
SOURCE: country code unlock
I need a unlock code for a 8700g blackberry country code, i'm in indonesia. tq
SOURCE: free unlock code for blackberry 8700g/ T-Mobil usa
i want blackberry 8700g mep code imei; 357890001341984
SOURCE: My blackberry 8700g does not charge
Have you tried both the USB and AV charger - The AV charger has the slide AV - which may be loose. I have never had a problem with USB connection.
If neither of this is working then it is most likely a problem with he battery? I have seen the curved battery warped and also non genuine - If these are the ones you have then I suggest a new battery.
Hope this helps.
