Question about Refrigerators
Frigidaire refrigerator our side by side refrigerator is running almost all of the time and we can't make it stop by changing the temperature dial. The refrigerator section is staying at 34 degrees and the freezer is staying at 0. What do we need to do?
  • 639 Answers
Friend,
ngfam1 At your service!
Sounds like your thermostat is malfunctioning.
Do not let it keep going like this without service or it will burn out the compressor soon by running non stop.
How old is the fridge????
now that's expensive and not worth investing in if the fridge is 10 years old or more the new refrigerates use much less power and can change your electric bill for the better !
Below I referred you to a great service nation wide!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
What would cause my freezer to freeze, refrigerator not cool, fan in back runs, motor hot
Good Morning Carlene,
I understand the freezer is freezing, in your Frigidaire refrigerator, but the refrigerator portion is not cool. I also see that the fan in the back is running and the motor is hot. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, stop the alarm, and press the "Factory Default" button. This will reset your temperatures to 37F on the refrigerator side and 0F on the freezer side. Keep an eye on your refrigerator temperatures, to see if they go down. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Refrigerators
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
Why does the temperature keep going up on the refrigerator side ?
the dial may be off or you could be getting cool air from the freezer to the fridge... also it could just be an internal mechanical problem
Dec 01, 2010 | Frigidaire FRS-26DR7D Side by Side...
Not cold enough all of the sudden
My refrigerator is running but not cool,the freezer side is about like the fridge side!
Dec 16, 2009 | Frigidaire Refrigerators
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
THERMOSTAT
Hi, Here is the Part # 5304421256.
This is a common issue with this model. Just remove the 4 screws holding the control panel up and you will be able to see the thermostat/cold control
I hope this helps you.
Please let me know if I can assist you further.
Vicl
Jul 05, 2009 | Frigidaire FRT17G4B Top Freezer...
Kenmore side by side model # 58582891- Fan will not run until....
I had same problem and while cleaning the dirt out, noticed the fan was stuck. unstuck it and has been working well since. Maybe too simple? maybe not.
Feb 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Appliance: Frigidaire 3.1 Cu. Ft. Compact Refrigerator Problem: How do I adjust freezer temp in my mini-fridge with top frost free freezer, has turn dial for refrigerator but no turn dial for freezer and...
The turn dial that controls your fridge temp also controls the freezer temp. The freezer air is directly forced into the freezer compartment and then sent to the reigerator. Adjust the dial for the fridge not to be so cold and it will adjust the feezer also. Allow about 24 hours for any noticeable change.
Apr 19, 2008 | Refrigerators
Power Problem
You will certainly have to replace the thermostat. Typical problem is once temp. is reached, it takes forever to come on.
Feb 29, 2008 | Frigidaire FRT8B5E Top Freezer...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
