Question about Carrier Heating & Cooling
Fan on outside unit not working..siezes up and makes loud squeeking when it does turn..system not cooling in house unless the fan turns
    Scholar:
  • 104 Answers
Need new fan motor.
Posted on Aug 31, 2008
Not cooling
are you talking about a central a/c system? the fan that blows is the indoor air fan? check breakers for outside unit. one breaker in the house panel box and a breaker at the outside unit. because other wise tha cap or contactor (for the outside unit) may be bad. both of witch may keep unit from turning on. unless you are knowledgeable about electricity I would not recommend opening the outdoor unit. you could get electrocuted. safety first
Oct 11, 2015 | Heating & Cooling
Turn on AC but outside unit fan doesn't move
Either a very bad Capacitor, or the fan belt came loose and the motor is just spinning
May 26, 2014 | Empire DV-215 Direct Vent Natural Gas...
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
I have a Tempstar 5000 that is about 15 yrs old and the fan motor to the outside unit will suddenly stop working and the compressor will start making a loud humming sound that does not sound too good. I...
Hello
Sounds like the condensor fan motor is going bad.If the fan stops turning or is not turning at full speed, the compressor can not give off heat to the condensor.Which will cause it to shut down on high heat.
So i would start with a new fan motor.Your local heating and cooling supply house should have these in stock.
Aug 01, 2011 | Heating & Cooling
Fan not turning and unit will not cool house.
Maybe you have a bad duel run capacitor. That capacitor would cause both the fan motor and compressor to heat up and turn off on internal overload. You may want to have a qualified techician test your system.
Jun 30, 2009 | Whirlwind FH-778 Air Conditioner
Motor outside is humming like it on but the fan isn't turning
Sounds like the run capacitor is bad or the bearings or siezing up. Turn the power off to the unit, then spin the fan blade to see if it spins freely, if it does then it's probably the capacitor.
Jun 22, 2009 | Heating & Cooling
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Heating & Cooling Logo
90 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
