Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
Code E 1
Dryer stops - shows E 1
  • 639 Answers
Friend,
ngfam1 At your service!
With an error code the only way to find to repair this is,
First unplug the dryer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
Like I used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I refered you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • 2,071 Answers
Just click below for spare parts and write your brand and model number..
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope this may help;
Regards,
VOTIT
Duet model GEW9200L. What does code 08 indicate?
there is no such error code on this dryer, that is likely the time left on the display... If the dryer stopped at the 8 minute mark with no error, check the door switch because it can interrupt a cycle, but will result in no error... Did you try to start it again, what happened? Whirlpool Dryer Main Control Board WP8546219
Jan 15, 2016 | Whirlpool Dryers
The dryer stopped and showed code E61.
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are receiving an error code E61 on your Electrolux dryer, it usually means that your dryer is experiencing an issue with the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason. Best regards!
Sep 01, 2014 | Frigidaire FAQE7072LA Affinity Series...
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
Dryer says ad stops mid dry
Good Afternoon Imadesigner Custom,
I see that you are receiving an AD error code on your laundry center, model# FEX831CS, and your dryer is stopping mid-dry. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your dryer, if it is still showing an AD error code, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FEX831CS Top Load Stacked...
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Invalid heating temperature
A dryer starts, runs 30sec and stops w/ code (hE) what panel do I remove to access the thermostats for ohm testing
Sep 09, 2012 | Samsung DV218AEW Electric Dryer
My dryer stops and a e1 code shows
This is a faulty sensor. Check with your dealer for a spare part.
Sep 29, 2009 | Kenmore Dryers
LG TD-C70040E dryer shows ELE/EHE code ....
This happened to my LG dryer and I took of the raised back panel that covers the flywheel and there is a red reset button. This worked for me.
Good luck
Funny how this happened after 3 years exactly. hmmm
Jun 14, 2009 | LG DLE5977 Electric Dryer
E-1 light
check owners manual should have a code listing. Have you checked the vent and venting
Oct 17, 2007 | Kenmore Elite HE4 Electric Dryer
Electric kenmore he 3 dryer what is code E-1 mean
This code is for a part called a "Thermistor". Its like a thermostat for an electronic machine.
Sep 06, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
