Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips magnavox 9P6040C104
The color is very dark. even with the brightness all the way up. everything has a red orange color to it
  • Armas Sep 04, 2008
    I have the exact same problem. The picture is dark and everything seems to come out a different shade of red. I've already tried to adjust the settings and that worked for awhile. I'm at the point where I know something needs to be replaced. I'm just not sure which part.
I just found out why, turn on ur tv and remove back look directly into 3 lenses, if the picture is not nice and clear or looks snowy in all 3 u will not get good color or brightness. I removed my blue tube assembly and took it apart WHILE OUT OF TV. there is cooling fluid between lense and tube, this fluid over time will build a film on the face of the tube and get thick enough to block the tube from projecting picture. (MARK EDGES IT GOES BACK TO GETHERE THE SAME WAY IT CAME APART).Find some new fluid then carefully dissasemble and clean interior of lense, housing and tube thouroughly. Reassemble and fill with new fluid. Do not use old fluid it will be cloudy and snow globe effect. Only do 1 tube at a time this will allow u to realign cross manually as close as possible before u perform convergence. Leave the green for last that is the center and the red and blue are moved to match green. Also be sure to clean mirror and back of screen. Pete
Posted on Mar 31, 2010
The color is very dull with the exception of red everything has a red tint to it other than that the rest of the 50" screen is very dark. Watching t.v. or movies are out of the question the color is...
Thats a very common problem caused by bad CRT coolant which will need replacement to restore the set back to normal colors and brightness levels. You can get the CRT Coolant kit at www.tvrepairworld.com which fits your model. The kit contains the coolant for all three CRTs and the CD with instructions.
Jun 24, 2011 | Philips Magnavox 51MP392H Rear Projection...
Color is way off like its being overrun by red and its really dark and cant adjest properlly and i tried configuring it but to no luck
Thats the coolant in the Blue and green CRTs causing the red to be dominate. Replace the CRT coolant and your color clarity and brightness will be restored. You can get the CRT coolant kit for phillips at www.tvrepairworld.com the kit contains the coolant and the CD with instructions.
Dec 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Projection television picture trouble
picture tubes are fine. just need to change out coolant
Oct 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Projection tv
the blue gun is not working properly which explains the dominance of green and yellow colors. you need to look after dry-joints on the blue gun circuit board, sometimes oil leakage from the lens may also affect the board
Mar 26, 2009 | Philips Televison & Video
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
51 projection tv dark colors
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
855 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
