Question about Maytag Neptune MAH5500B Front Load Washer
Water Sounds When washer is finished and clothes are removed, if you manually turn he drum you hear water cycling around the drum, not a littl but a lot. A gallon or so from the sound
  • 639 Answers
ngfam1 At your service!
This is normal for the Neptune!
I used to have a Neptune and I sold them too!!
The machine is wringing out the clothes good??
The Neptune comes new with water in ti from the test run!
All the water never gets totally discharged. This is one reason why everyone complains about the mold, musky or even stinky smell of the Neptune! Every day i have people here asking what too do about the moldy wet smell!
I do tell them to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make suer to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
That's Maytag!!!!!!!!
Perhaps they will make some good changes!!
Hope this helps and makes you feel a little better as to some water sounds! HOW OLD IS THE WASHER??????
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
Hoover washer dryer - not sure it is filling with enough water
How old is the machine and which wash cycle are you selecting? Newer machines use very little water; it is not needed.
Mar 08, 2014 | Dryers
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Water is always left in the machine when the cycle finishes
Because the water pump operates as a timed cycle, a partially blocked water passage either from the outer drum to the pump, inside the pump, or from the pump to the house drain is restricting the amount of water being pumped. Remove the drain hose from the house drain just enough that you can watch the water flow during a normal pump cycle. The water should be coming out quite forcefully--if just a trickle, then something is blocking the flow. Look for kinked hoses or even a slow running pump.
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
May 20, 2009 | Asko Washing Machines
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Mar 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
