Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker my ice maker wont make ice, makes clicking sound The ice maker will not make ice. The part that goes down to release ice just stays down. My icemaker has been making ice since I bought it and all of the sudden it quits making ice. It is Model 106.53532300. It feels like it has made ice but hasn't dropped it
  • Mary Montgomery Pestel Sep 01, 2008
    Thankyou for the information i will call a repairman
  • 639 Answers
Friend,
ngfam1 At your service!
There are many parts in this component that may be the culprit .
One or more will need to be replaced.
This is not easy to diagnose. I've seen service order parts 2 or 3 times till they completed the ice maker repair on a side by side fridge!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Aug 31, 2008
  • Neil
    Neil Sep 01, 2008
    okieduffer
    You will be fine
    Bless You ngafm1
    DID YOU GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
Apr 25, 2012 | Kenmore Side by Side Refrigerator
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Automatic Ice Maker making grinding noise and will not release ice
The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
May 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore ice maker not releasing ice - it stays in the bottom and ice maker makes sounds like it's trying to kick it out but doesn't. It's frozen in a big block.
Sounds as if your water valve is letting too much water in and too big of ice cubes won't let the rake strip out the ice. Look and see if the ice in the tray is up to the round arm with the fingers. If it is then the water valve needs to be replaced but you will need to get that ice outta there. Take the ice maker down by removing the 2 screws holding it above the tray. Sometimes there is one under the tray as well. Unplug the ice maker and run hot water over the tray keeping the water away from the electronic part. This will release the ice and then reinstall the ice maker.
Another possible problem is the motor module may be broken. Pull the white cover off the front of the ice maker. This will take a little elbow grease. When you access the module (You will see a white dial about as big as a half dollar) see if right in the center of that dial one of the two prongs holding that dial is broken. If you pull on it a bit and it comes off then you are sure that your module is bad. To replace it...remove the three Phillips head screws holding it on. The shut off arm will also be attached...just pull it out with a good tug. Pull the module straight out and replace the module. When replacing the module, you may need to rotate the arm in the ice maker with the fingers on it to fit in the slot in the center of the module. You should have ice within two hours.
Apr 11, 2009 | Refrigerators
Ice maker keep making ice
It will not cut off unless the arm is raised to the highest position and will lock unless it is broken.
Jan 04, 2009 | Kenmore 55693 Side by Side Refrigerator
Ice maker
Hello Carol34,
I'd like to help you but you will first have to provide some additonal information. First off, did it ever work? Not sure what you mean when you refer to the 'part that goes down to release ice just stays down".. are you referring to the arm that shuts off ice making when the bucket is full? Please provide this information so that we can get your ice working again..
Thanks
Aug 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice Maker not making ice
replace the icemaker is the best solution , or possibly jst the control module
Jan 14, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
140 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
