Question about Smeg Dishwashers
Smeg dishwasher L5 eco when dishwasher on button is pressed, unit does not start appears to be faulty switch underneath on light is on when door open, but goes off when door is closed
  • Anonymous Mar 12, 2014
    D1876 95.4 Door closed switch faulty. please advise location
  • Anonymous Mar 15, 2014
    door has dropped suddenly with loud bang and now has no cushioning support. instead needs to be manually supported when opening and closing?
Brought a new dishwasher
Posted on Aug 31, 2008
How do you reset a smeg DI612C dishwasher?
Just unplug or kill power for about 10 minutes. see what that does but you may have another issue. see if water fills into unit. Also check flod switch for debris
Feb 17, 2013 | Smeg Dishwashers
No error message, topped up rinse aid, turned off power at wall for 45 minutes, unable to press program buttons - it's like they are stuck - which would be unusual as it worked perfectly a few days...
Hi.
Turn off power again tripping circuit breaker or disconnecting the power cord. While power is off clean the drain well and remove any water present inside the tub using a sponge. Check also the door lock.
Connect power back and try starting a cycle.
If still no luck, let me know the appliance model number. In that case the dishwasher is probably faulty. A defective door switch or faulty control module may result in appliance not responding to commands.
Regards.
Ginko
Aug 29, 2011 | Smeg Dishwashers
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
Unit just quit. won't start up. press start button and won't even light up
please provide the model number of the Samsung dishwasher.
if none of the lights light up, then a fuse might be blown somewhere. If the problem is the start buttion does not start the dishwasher , then the door latch switch could be faulty.
Jun 23, 2011 | Samsung Dishwashers
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
I do not have manual for this dishwasher and am unable to start cycle, has been working up until today have checked obvious things like power and water. I usually press start botton then press P until it...
Possible that the controller unit has got some errors or is faulty. remove the mains plug and keep aside for few minutes. Then switch on to test. If there is no result then you might have to check the power to the controller unit. Use a multimeter to test the voltages to the circuit . Make sure you take all precautions when dealing with power circuits.
Dec 14, 2010 | Dishwashers
Dx103wk will not start
You will need to be a bit more specific about what does "will not start mean"
Do you see the lights on the panel
are you able to set the wash program
are you able to press the start button.
Does it start and then stop or it never does anything except flash lights when you press the strart button.
If you have shut the door but pressing the start button causes no action then most likely the door switch is faulty or the door gasket is swollen and does not let the door close properly.
Please post a comment to take this fruther.
Sep 24, 2010 | Smeg STX2 Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
433 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
