Question about Maytag Dryers
Maytag dryer model # MDE4000AYW, Serial # 28636682YK: When running the machine ha low pitch growl and vibration. Possible belt problem?
  • 639 Answers
Friend,
ngfam1 At your service!
Yes, Possibly a belt needs to be changed!
Do not put off the service call for delay may cause more severe problems if it is not a belt. ANY TIME YOU HEAR GRINDING SOUNDS LOOKOUT! A belt is usually only a squealing noise!
A good company to use that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
How much is a used Maytag dryer model #:MDE4000AYW. Serial #:28623615YH
Ashley,
That is a 15 year old dryer and I would not pay or sell for more that $100 for it. Possibly even less depending on how clean it looks.
Jul 12, 2015 | Maytag Dryers
Maytag Model LA610 - Newton - old style counterweight transmission (mfgd.1981)
check motor coupler, agitator spindle, drive block and shaft, cam dogs and motor windings
Mar 23, 2017 | Washing Machines
Maytage la610 - Newton - old style counterweight transmission (mfgd.1981)
It is possible that the motor may be on it's way out. You might check to see if it has a start capacitor on it that may be getting weak and possibly by pushing the agitator takes the initial load off of the motor. Just a thought.
May 14, 2014 | Washing Machines
Maytag mde4000ayw won't start. moisture monitor
This is either your start switch or your motor that is bad. I would suggest you begin with the start switch. We love Maytag appliances and we also love the moisture monitor on this model of dryer.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct switch out to you asap.
We look forward to working with you and hope to get you back to drying right away.
Happy Holidays to you!
Ella
Nov 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
Hi I have a Maytag MDE4000AYW dryer. It is making a squeeking sound off and on when it runs. I took the front off and kinda lifted the drum up and down and it made it without the belt actually turning,...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
You did the right thing by removing the front of the machine, that is how you check the drum rollers, idler arm with pulley and the motor.
Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
There is a low pitched growling noise coming from the ac compressor of my 2004 grand caravan when engaged at idle. Compressor, belt, have already been replaced twice. Any thoughts?
Are you sure the noise is coming from the compressor and not the belt tensioner or other accessories, when you turn the ac on it put more of a load on the engine. If not since the compressor was changed twice was it properly oiled and the clutch turned manually to insure proper lubrication. I am hoping if it is the compressor that the reciever dryer and expansion valve was changed and the ac system was flushed well, to insure no contamination, or blockage damaging the new compressor.
Jul 08, 2009 | 2005 Dodge Caravan
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Dryers Logo
176 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
