Where is your web site for k 3.91 warranty registration?
  • 639 Answers
MODEL AND MANUFACTURE WOULD HELP ANSWER YOUR QUESTION??????????
Posted on Aug 31, 2008
Registration new water heater
Unknown brand and type water heater.
Tank, hybrid, solar-assisted, indirect, tankless, condensing, gas, electric, under-counter, RV, mobile home, etc?
1) Water heater warranty-coverage does not require registration of product. Usually the registration can take place at manufacturer's site, but not all sites have registration forms.
http://waterheatertimer.org/Water-heater-manufacturers.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#warranty
http://waterheatertimer.org/How-to-maintain-water-heater.html
2) Almost all water heater warranties cover original owner, one-family household installation, when product is installed according to product manual. SO if you register product, then move to new home and take expensive water heater with you, then the registration does not show new address, thereby voiding product warranty because it was relocated.
3) Warranties after first year usually cover parts and tank. Many warranties today are pro-rated, which means longer warranty is becoming almost valueless.
Jan 03, 2013 | Rheem Water Heaters
Praduct registration card
you need to register on web site before you can register for the warranty.
Jan 17, 2009 | Samsung Cell Phones
Registration & Warranty?
I cannot find sitefor registration & warranty for my new microwave that i purchases. Iris
Jul 30, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Registration
Try this link - it is the original site of DANBY. Not sure about the 2 yr warranty issue, but you can check with them at http://www.danby.com/contact_us.
It's always a good idea to check your spelling when you type in a web address. The correct web address is: http://www.danby.com
Jun 29, 2008 | Danby DMW1153 Microwave Oven
Warranty
please contact the customer service division of the company
Jan 03, 2008 | Cameras
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
