Question about GE Microwave Ovens
Fan vents house vents come down from top microwave vents come in from the back what can do to solve this
  • 706 Answers
Most microwave oven fan systems can be rotated for either back or top venting.. This can be done by removing a few screws and rotating the blower housing to the position you need and screwing it back in place.. Hope this helps..
Posted on Aug 31, 2008
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Jul 29, 2014 | Maytag MMV4205 Microwave Oven
Screw/nail in microwave housing loud rattle when exhaust fan is on.
A screw that falls into it from the top should be in the vent fan in the top rear of unit. I think you will have to take the unit down from the wall, at that point, either remove the vent blower fan and shake it out, or turn the whole microwave upside down and it may fall out.
Oct 17, 2017 | Whirlpool GH7208XRS Stainless Steel 1200...
Converting the vent fan on a GE Combination Oven
is your house vent connected properly? no restrictions?
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Venting of microwave - house stinks of bacon
Interesting post, because I have the same problem! I have spent the better part of today researching and taking our microwave apart (partially) to inspect the top portion re: outside vent. Everytime the microwave is on, the "active vent door" (manufacturer's term, not mine!) opens. Apparently this is normal. But it also opens when you turn on the vent fan, when cooking on the stovetop. I don't like this feature, because I think it 'overrides' the outside venting system. I double checked our outside vent to ensure that when this oven was installed, the person did in fact allow the flap to be open when the fan is on (he did). So I think what 'our' problem is, is that the microwave active vent sort of interferes with the outside vent, thus more of the cooking smell being blown into the house instead of the outdoors. I was thinking of simply disconnecting the gizmo that make the active vent door open each time you use the oven and/or vent fan option however I don't think that's a good idea as apparently the main purpose of the active vent door is to keep the electronics of the microwave oven from overheating. The more I read about this version of microwave, the less impressed I am with it. Lots of electronic issues with it. I am not fussy either with having the microwave over the cooktop. Sorry I don't have a solution for your problem but I do feel your pain!!!
Mar 21, 2010 | GE Microwave Ovens
Can this microwave be vented to the outside?
Yes, this microwave will vent either out through the top or the back. A damper will be needed if it was not saved when the unit was installed. A list of other items are listed in the installation instructions at this link To GE.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My whirlpool microwave was hooked up but doesn't seem to be venting out the roof. It has a vent running from the top of it through a cabinet and out the roof. What might be blocking the venting process?
the fan motor needs tobe turned around take screws out of top front remove front fan grill pull out fan assibliy and turn around. this will pull air out of your house
Sep 21, 2009 | Whirlpool MH7140XF Microwave Oven
No vent for over the range microwave.
Have you selected a microwave yet?
many over the range types can be vented inside if a charcoal filter is used, which you must replace about every six months.
Otherwise, you will need to install a vent system in the kirtchen.
Aug 20, 2009 | Microwave Ovens
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
Mouse in vent fan?
Yes, the mouse was probably attracted to the warmth and food odors in the duct work and may have gotten trapped in the vanes of the fan and died. I'd act fast...
The best bet is to remove the oven from the wall, or almost from the wall, so you can see the area of the hood vent exhaust fan.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Dec 09, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
