Question about RCA Televison & Video
RCA 27 inch TV shut down and will no longer turn on
Hi,   My 27" RCA TV recently decided to just up and quit.  The TV was working fine (powered up) and then just quit  I tried unplugging the set and then plugging it back in, but no go.  When I go to turn on the TV with the power button, the red LED blinks about 24 times and then stays lit, but nothing else happens.  I have checked the horiz. output transistor and that is fine.  The 3 fuses on the switch mode transformer secondary are good na dnot blown.
Any ideas?
  • 1 more comment
  • Dave Anders Sep 03, 2008
    I'm not exactly sure what you mean by the power supply "module"? Are you referring to the IC voltage regulator on the main PC board? My TV has three boards .... the main chassis board, the CRT board and the ADM board.
    I'm pretty much convinced at this point that the problem is due to a bad microprocessor (IC 200) but I'm not 100% certain.
    Unfortunately, a replacement microprocessor is no longer available from RCA or any of the parts suppliers that I deal with.  This is RCA part# 272008.  Thanks for the help!
  • Dave Anders Sep 05, 2008
    Yes, thank you. It is unfortunate that a new microprocessor is NLA from RCA for a set that is only two years old, but thanks for your help with the diagnosis.
  • RCA Master
  • 6,487 Answers
This is a some IC problem on the ADM board probably some busted IC 's there that needs replacemnet..
Hope that helps........
Posted on Sep 03, 2008
    Brigadier General:
  • 6,966 Answers
I am assuming based on your post that you are comfortable and familiar working with electronics, use of a DVM and a soldering iron.
Pls post back the specific model number or preferably the chassis number of the TV. Additionally, a schematic diagram or better yet a service manual would be of help. Initial tests would involve the standby +5 and the different output voltages of the PSU board without load.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 521 Answers
If all the three fuses are ok.then you r right the only reason causing this problem is bad microprocessor .
pls do rate the solution
thanks.
regards.
fixya expert team
    President:
  • 1,263 Answers
The power supply module is malfuntioning this can be replaced by a local service tech.
Posted on Aug 30, 2008
My 27 in truflat worked fine ,then it just shut off,,,now it keeps coming on and shutting back off constantly
You have developed a shut down issue that can not be resolve other than by a TV repair specialist. This TV is know to have issues with a device called the IHVT (Intergrated High Voltage Transformer). Given this unit is an old CRT based NTSC type I would not see much use in repair unless you have a specific need. The parts for this unit is very difficult to find since the Manfuacture TTE is no longer in business.
Feb 18, 2011 | RCA TruFlat 27F520T 27" TV
I have a 27 inches RCA TV (model:27R410T) , Firstable when i turn the tv on ,it works fine but just for about 2 minutes , after that video has gone , no video only audio ,and start changing channels...
It maybe some semiconductor IC got hot, need service or repair. It may repair itself if you leave it on standby for a month(at operating temprature a week)? This is low tempeature(the lower the temperature the longer the time) annealing or moisture curing technology, used by Nasa on transistor failure in satellites, or long range unmanned vehicles. You can always repair the unit later.
Aug 26, 2010 | RCA 27R410T 27" TV
Turn tv on, shuts immediately off.
Same problem with my 28 inch 16:9 CRT Sanyo. I usually fix it by cutting the power to the outlet and then it works fine. Had it into the repair shop - and of course it never acts up there...
Jan 27, 2009 | RCA 27V520T 27" TV
No video
Take out all of the leads going to the tele and replace them again. Make sure any hardware you have hooked up to the tv has the leads inserted correctly
Oct 14, 2008 | RCA TruFlat 27F520T 27" TV
RCA 27 inch TruFlat TV/ Walmart Feature Item "Defective!"
I have the same RCA Tru Flat 27 inch (NON HD) TV I bought in December 2005.I am having Various problems with this TV ,First the sound is never stable ,Goes up and down constantly,also notice can only turn on thru remote,the front button doesnt work.Does anyone know if this is worth fixing (under 200)or should it just be trashed.
Feb 28, 2008 | Televison & Video
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
27in RCA
have a tech repair your tv the power supply is deffected.good luck.
May 14, 2007 | RCA 27V530T 27" TV
Tv was working fine...then shut itself off.
there is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Nov 21, 2006 | RCA F27242GY 27" TV
Televison & Video Logo
166 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
