Question about Breville SK500XL Stainless Steel Cordless Electric Kettle
Breville steel ketell dose not start had started it with no watter inside it heated up immidetily i turned it off and added water then turned it on but it wouldent start would it be the fuse if yes how to re set it
Seriously, that worked for me!!
Posted on Mar 15, 2010
  • Fayette Fung Apr 14, 2012
    Did you find a solution to reset it? I'm also looking for the same solution
The pot has to little white spring loaded sensors in the middle of the underside. I found that one of them was sticking in the "in" position and used a pen to unstick it. the part started working again immediately.
take a look it might be this.
Posted on Oct 27, 2008
LOL
Posted on Oct 22, 2008
What are the features of Breville BES870XL Barista Express Coffee maker for my home. Where can I buy it in good discounted rate?
FEATURES OF bes870xl_barista is as follows -
  • 15 Bar Italian Pump and 1600W Thermo coil heating system
  • Purge Function: Automatically adjusts water temperature after steam for optimal espresso extraction temperature
  • Stainless steel conical burr grinder with 1/2 lb. sealed bean hopper
  • 67 fl.oz (2L) removable water tank with handle
  • Newer model of the Breville BES860XL Barista Express
It has stainless steel color. And you can order it great discounted rate from where I purchased it after comparing all the other brands and prices also. Best Espresso Machine is one of the best site to compare and get best detailed knowledge of every brand....
Oct 07, 2016 | Breville Coffee Makers & Espresso Machines
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Doesn't heat the water Start...makes noise, the
the flashing heating light indicates that it isn't getting water. This could indicate that your pump has gone bad.
Oct 15, 2010 | Breville Die Cast 800ESXL Espresso Machine
My Breville Keurig coffee maker turns itself off after heating water...why?
mcdevito75 here, It may need to be cleaned, if the brewing holes are clogged it"ll signal coffeee maker to shut off. Refer to owner manual for cleaning.
Jun 22, 2010 | Breville BKC600XL Coffee Maker
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
BKC600XL Stainless Steel Coffee Just purchased...during the priming no water entered the machime and it is stuck on "heating". I think i had the water filter on wrong. I fixed that but now need to reset to...
After trying just about everything (I had the exact problem you describe) I finally got it working.
In my case the reason why it was stuck on heating is because no water was getting into the heating tank. I removed the charcoal filter, unplugged my machine and plugged it back in again. I then saw the water resevoir level drop and knew that water was now being heated.
I made a couple of cups of coffee then put the charcoal filter back in and now everything is working great.
I hope this helps your problem.
D
Dec 12, 2008 | Breville BKC600XL Coffee Maker
Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
May 12, 2008 | Breville ESP8XL Espresso Machine
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Breville SK500XL Stainless Steel Cordless Electric Kettle Logo
639 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
