Kenmore Elite Calypso - washing stops in the middle
The washer will stop half way through the wash cycle and will not allow me to stop and re-start. It will stop when it reaches 16 and if left for awhile I can restart the machine and it will again stop at 16.
  • Anonymous Mar 18, 2014
    why the machine always restart and stop when I wash for awhile??
  • 639 Answers
Friend,
ngfam1 At your service!
First unplug the dryer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
Like I used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I refered you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Model # 110.22064101 Kenmore calypso elite washer makes a whirring sound when washing and the washer tub doesn't always stop correctly when the cycle is complete. It will move around instead of being...
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
Nov 10, 2010 | Kenmore 24032\24036 Top Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
Washing Machines Logo
Top Washing Machines Experts
