Question about Compaq Presario R3000 Notebook
Display brightness I just fixed the power problem. The battery now charges fully. Odd thing... In the past when ever I work off the battery, the screen dimmed to save on power. But when the power was on, the screen would brighten... Now, the screen is dim when the power supply is in... and it brighten when it runs on battery. Which drains the battery way to fast...How'd this get switched?
    Guru:
  • 257 Answers
That poroblem comes from your Motherboard and there are some trasistor that we be remove and resold anotherone where did you stay because this will be feine to an engineer to sit down and tackle the problem
ok
Rata this solutio
Posted on Oct 17, 2008
On the ride the battery gets drained of power. When the battery loses power the bike loses revs. Is this the regulator and how do I test it or is there something else to check?
Same thing happened to me. It turned out to be a corroded connection from the alternator that snapped off when inspected. The first thing to check is battery condition. A fully charged battery should be around 12.5 volts. When the engine is running the voltage should increase to around 14.5 volts. If it does increase then your charging system is working as it should and the problem lies elsewhere (possibly a battery that is past its best and needs replacing). If it doesn't increase the voltage, then chec the wires from your alternator (ther should be 2 wires) and follow these to the junction connector. This was where mine was badly corroded. I used more cable to bypass this connection and my problem was fixed. I then replaced the connections with new ones and all is fine. The bright yellow straw is pointing to the corrosion problem. Hope this is of help as totally replacing your alternator isn't cheap.
Mar 11, 2015 | Power Motorcycles
I've got a hitachi 2nd fix nail gun and for some
First thing is , when did You clean it last?
Sep 30, 2014 | Tools & Hardware - Others
Dear Sir, I am having dell vostro 1510, from the past few days when i put on my ac adopter the battery indicator lights gets on but suddenly after 3-5 sec it get off again.I am not able to charge my...
You either have a faulty a/c connection and need to buy a new one at any common electronics store, or your battery cannot hold a charge.
Factors affecting battery:
Mar 29, 2011 | Dell Vostro 1510 Laptop
While switched on the phone screen has gone black/blank. Battery is fully charged. Nothing is working.
may be the display of the phone is damaged or the power cable to display is slipped. Contact your nearest service provider to get the things fixed
Dec 29, 2010 | Nokia Cell Phones
Sometimes when i try to take a picture - the camera won't let me - a flashing hand appears on the display screen and it won't let me take the picture - i have the camera on auto adjustment - i just want to...
If it is set to auto then about all I can think of is low light pictures and you may have the flash disabled or the battery level is too low to power the flash .
Try taking a picture in bright sunlight and see if it behaves. I can't recal if that model disables and enables the flash with the menu or if it has a button on the case looks like a lightening flash. And don't forget to charge your battery
Apr 12, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Back light fine with power supply and goes off on battery.
I would need to know what operating system you are running because Vista has a setting for the display brightness when running on batteries. I would suspect that, that setting is turned down to conserve battery power. If this is not the case, then the battery may be too weak to put out the correct voltage requirements for the display. If you have Vista, go to the control panel > power options > In the left pane, look for the display brightness > here you can change the brightness for running on battery and for AC power.
Oct 14, 2009 | Dell Inspiron 1720 Notebook
Canon 1000d display blank when power on,battery charge full
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Compaq Presario R3000 Notebook Logo
180 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
