Question about RCA RT2360 System
Can i get istructions for the system i can print off my computer
Hook it up to my dvd player an tv
Can i get instructions for the the system i can print...
Posted on Nov 14, 2008
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
How do I hook it up to my TV. or do I hook it up to my DVD player?
You usually hook it up to your DVD player, but if your tv also has surround sound out, give that a try, see which you prefer.
Sep 04, 2010 | Logitech X-530 Computer Speakers
Can not hook my hdtv phillips tv to my dvd and
That is because your player does not support an HD signal and cannot complete the signal from one system the other.
Nov 28, 2009 | Pioneer DV-563A DVD Player
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Need help hooking up my duraband surround system to my tv and dvd,tv has 1 set of holes in front and dvd player has in and out
plug the dvd audio into the amp and video to the tv if you have an output on your tv plug it in too.the amp. plug cable in back of tv
Jun 24, 2009 | Durabrand 5.1 Surround Sound Computer...
Need home theater hooked to TV with built in DVD
This is the easiest way 2 explain it. Hook up on the home theater should be labeled in and out. same as on the tv. The TV might no have that feature as the DVD is built in. You might just have an option for sound from the TV/DVD to the home theater. Again OUT from TV IN to receiver. Same with any other device set up.
Jan 27, 2009 | Durabrand 5.1 Surround Sound Computer...
Problems hooking it to the television
The colored jacks match up to the jacks on tv. Tv must be turned to AV channel, Or input channel. The ports they are plugged into should have a channel printed by them.
If you are hooking it up through a VCR it is the same. Whatever it is hooked up to has to be on the right channel.
Channels are usually: AV or Input
Jan 18, 2009 | GoVideo DV2140 DVD Player/VCR
I want to print instuction
how to hook up to a sharp tv..nothing seems to be working and what cables do you need to hook up
Aug 07, 2008 | Samsung DVD-V5500 DVD Player/VCR
RCA RT2360 System Logo
79 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
