I need to set my display settings to 1024x768 pixels or higher, i dont know how.
    Master:
  • 397 Answers
Start>Control Panel>Display>Settings
In this window you will see the screen resolution on the left, just move the slider across till it gets to 1024X768 and click OK
Posted on Aug 30, 2008
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
My microsoft office display change the bits and resolution whenever I use it
what is the size of your screen in inches? cn you set your resolution to 1024x768 pixels or higher from your control panel. I know if it is really a resolution problem, this should solve the issue.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 17, 2011 | Computers & Internet
Resolution is not set to minimum 1024 X 768 pixels
this is not a problem this is a disadvantage of an internal display card of the motherboard .Install an AGP card into an AGP slot then you can see the higher resolution.
Apr 12, 2010 | HP w1907 LCD Monitor
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Fix ressolution on aspire to fit 720 pixel tv
Connect the laptop to the TV and use the keyboard toggle to switch screens.
Once the display is shown on the the TV go to the control panel and select display, set the screen resolution to 1024x768 and your display should be fine.
If you need anymore help or advice please post back.
Regards.
Aug 01, 2009 | Acer Computers & Internet
When in gmx,letters are too large .How do I set the display back to normal.
right click on the screen then select properties..while on display properties click settings..under the screen resolution, adjust the slider bar to the right until the pixel is 1024x768..adjusting to the right decreases the pixel and to the left increases the pixel.. under the color quality select highest (32 bit)..click apply then OK..when prompted to keep the settings click OK..
Jul 19, 2009 | Acer Computers & Internet
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
May 29, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
