Question about Lexmark Office Equipment & Supplies
I keep getting the same error on my printer sayin there is a paper jammed but this is not the case i am using lexmark 6200
    Guru:
  • 1,894 Answers
After clearing the error you must do a hard reset.
did you do that?
its done by leaving the printer plugged off from wall power for one night
Posted on Aug 31, 2008
  • dewan nafees ahmed Aug 31, 2008
    also please post us the suggestion you have tried till now.
    so that we can avoid repeating the same
    please post a detailed view of the problem. and the attempts by you to clear the problem.
    thank you
    Master:
  • 848 Answers
There may be some problem with the roller .......
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
Sx218,keeps sayin paper jam when there isnt any paper jammed
It sounds like a sensor is stuck. Sometimes a very tiny piece of paper is stuck near the sensr. I use a flash light to check. Have you tried turning off and on? Sometimes that will clear the error message.
Sep 06, 2011 | Office Equipment & Supplies
Hi, I keep getting paper jams, it prints approx 5-8 pages then jams. I am using standard office issue paper.
Do you get an error code? If not, please make sure that the paper settings on your printer is in sync from the application you are using. (e.g Microsoft word). Also, make sure that paper is properly stacked on the tray and the paper guides are secure. If you need further assistance please contact Lexmark Technical Support Center.
Jul 18, 2011 | Lexmark C736DN Laser Printer
My Lexmark X4690 printer keeps telling me there is a paper jam when there is no paper jam. It won't print. How do I solve this?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 06, 2011 | Lexmark X3470 All-In-One InkJet Printer
Printer now very reluctant to pick up the paper from the tray, keeps reporting paper jam. Think this could be a problem with the rollers
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider2_bing.gif to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 15, 2010 | Lexmark E232 Laser Printer
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
My lexmark x4650 keeps on getting paper jams and i think its something to do with the roller so any info please help :D
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 13, 2009 | Lexmark X4650 InkJet Printer
Paper jam in lexmark all in one x7170
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Move the Catridge Carrier which holds the Catridge Back and Forth for abt 20 Times as fast as u can.............
Turn On the Printer........
Good Luck...........
Apr 05, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Printer says paper jam, but no paper in there
use a flash light check all paper path, specially the area around the toner. all you need is a small piece or other (dust). There is a micro switch that detect the paper travel. so if anything preventing the switch to open, you will get error message.
after that, open the toner door, reseat the toner and close the door. the pirnter should return to normal.
Oct 23, 2008 | Enlight Intel Xeon 470 WATT EN-470 MP...
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
