Question about Nikon (8320) (13-30x50 mm)
Nikon N70 back covered
My Nikon N70 back is covered with rubber. I always wipe it after use. Camera is stored in a plastic bag all the time. A thick sticky film accumulated in this rubber surface. If I scratch it with my nail it leaves a scratch in this film. All adjacent plastic surfaces of the camera body are clean. Alcohol did not remove it. What do you recommend? Did anybody have the same problem?
Find some methanol. The local hardware store should have some in the paint section. Use paper towels and wipe, wipe, wipe....
Soak and lightly rub an area for 10 seconds or so, then use a dry section of towel to wipe and mop up any goo that has been solved. You may not see much improvement at first, keep at it. It took me nearly an hour to get mine completely clean of all goo and residue.
Take care not to splash the meth/goo mix onto the optics, shutter, etc. Once the solvent alcohol evaporates, any dissolved glop will precipitate out and muck things up.
Posted on Mar 22, 2009
Kirby Ultimate G Diamond edition vacuum. We were told you can wash the outer bag. Is that true? How do you remove the bag to do this?
Twist the bag emptor left to remove it from the upright then your need a sharp narrow pointy object (like a metal dental pick cost $1 in most stores) push it under the plastic band around the rubber on the bottom of the cloth bag roll it across and take off the plastic tie once off pull the rubber bottom part of the bag emptor take out the inner plastic tube and zip the bag put in the washer by itself and wash with soap and softner and let hang dry you can also wash the inner plastic tube with hot water and fabuloso I recondition kirbys and do it all the time.
Jul 07, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I have lost the plastic cover for the back screen of Nikon N90.Is there a possibility to buy a new one? Thank you and with kind regards,Karolina
You can order the BM-10 LCD Monitor Cover from Nikon at
Mar 16, 2011 | Nikon D90 Digital Camera with 18-105mm...
Nikon N70 back of camera and area covering that opens up to expose film, the individual "strips"covering that opening were inadvertantly pushed in and need to be reset into opening...How?
They can't. You've destroyed the shutter assembly and it must be replaced which is a professional job. You cannot simply push the shutter blades back into place and expect them to work correctly; they're a precision assembly manufactured to very fine tolerances.
N70's are now near-worthless, so repairs make no economic sense at all. Just look on FreeCycle/Freegle and get a replacement for free: it's where I get most of my Canon and Nikon 35mm SLR's and also where I get occasional Mamiya or Bronica medium format models.
Aug 05, 2010 | Nikon N70 35mm SLR Camera
How do you set shutter speed on a nikon n70
In Manual exposure mode, you can change the shutter speed by turning the command dial on the back of the camera.
If you need a manual, you can download one from
Jun 14, 2010 | Nikon N70 35mm SLR Camera
Broken latch on film door
Usually on this level Nikon it was a plastic "hook", part of the door moulding, that was retained by the latch mechanism in the body. The broken part may still be in there - if it is trip the latch and recover it with a tiny screwdriver or even a needle. If you can't find a replacement back door you can try welding the hook back in place with a low-temperature soldering iron - with the tip perfectly clean and a very steady hand - as long as the door is thermoplastic and not thermosetting. If that doesn't work bend a paperclip or similar to exactly the right shape with the free ends (roughened) long enough to extend into the plastic of the door by 4-5mm., heat the wire and push slowly into the edge of the door. There are many variations of this technique that I've used, all require extremely careful work! Best tip: spend more time thinking than doing. Good luck.
Nov 28, 2009 | Nikon N70 35mm SLR Camera
Broken Nikon lens mount
I'm another very unhappy victim of the defective manufacturing and/or materials in this lens. My 18-105 DX VR lens lived in a padded camera bag when it wasn't on the camera. It's never been dropped, banged, dinged, or put under any stress. 10 months into ownership, with 50 months to go on the 5 year extended warranty, it simply came off in my hand one day while zooming. I was horrified to see a thin black plastic sliver inside the camera body -- the mount just broke off. Thankfully did not get behind the mirror or on the sensor. Greatest insult came from Nikon repair, who refused to honor the warranty because "the lens had been dropped" and asked me to pay nearly 1/3 the original cost of the lens for repairs. When I challenged this and pointed out the as-new condition of the lens, not even a scratch, they simply stopped responding to my emails and phone calls.
Jul 22, 2009 | Nikon D90 Digital Camera with 18-105mm...
Rubber Grip Has Developed "Sticky Spots"
The best and cheapest way I have found is to use 91% isopropyl (rubbing) alcohol...put a little on a paper towel, cloth, or cotton swab and rub the stick stuff off. I would also suggest putting on rubber gloves to keep the black stuff off your hands. Have fun.
Oct 03, 2008 | Nikon F65 35mm SLR Camera
Camera failure in high humidity conditions
First put in an air conditioned environment to 'dry it out' Get a snap shut 'Poly' bag and lots of Silica Gel bags or even Rice in a cloth bag to take up moisture. If you are really clever you could organize the bag so the lens pokes out through a hole with a Rubber band sealing the bag around the lens barrel Keep it in it. From time to time rake out the absorbent bags to dry out.
May 18, 2007 | Nikon Coolpix 8700 Digital Camera
Nikon (8320) (13-30x50 mm) Logo
670 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
