Question about Cobra 18 WX ST 40-Channels Base CB Radio
Mic wiring i am trying to wire a d104 mic to a emperor ts5010 radio
  • 204 Answers
Hello, In case you haven't found it yet, here is for a 2510/ which is a cousin of a radio.
1 - Modulation/ Audio/ White
2 - Ground/ Shield
3 - Transmit/ Red
4 - up button/ NC
5 - down button/ NC
Thats if the D104 is a 4 wire, Mechanic
Posted on Nov 05, 2008
How to wire a D104 mike to a DAK IX Base Radio
Is the d104 a amplified tug8 (4 wire) or tug9 (6 wire)
or is it a non amplified mic?
Found this...hope it helps..........
Astatic (4 wire)
1- White
2- Shield
3- Black
4- Red
Astatic (6 wire)
1- White
2- Shield
3- Blue
4- Red
Black- N/C
Yellow- N/C
Dec 15, 2017 | Radio Communications
Microphone wiring
the rf power going out is geting inducted on the wires of the mic.try using some ferrites close to the coax on the pl259 connector and on the mic wire itself.
Mar 01, 2014 | Radio Communications
When i keyup my d104 mic on cober 148 gtl ihear feedback squeal.but the d104 work good cobera 2000 gtl
try to keep the mic away from the radio speaker.check to see if its turned up to high.check your mic gain to make sure its like 1/2 open.If these fail then you could solder two 0.001 ceramic disc capacitors from the audio to the shield wires about 3" apart.then on the audio wire in between the 2 caps solder a 4700 ohm 1/4 w resistor.this should work.
Nov 09, 2013 | Midland 1001Z 40-Channels Base CB Radio
Need to know how wiring goes on a cobra 4pin a d104 desk mic
match up the wiring diagram on the mic to the wiring on your radio.www.cbtricks.com
Dec 15, 2012 | Magnum DeltaForce CB Radio
I have a emperor ts-5010 that i would like to put a d104 hand held on but cant find any mic wiring for this sort of thing
  • Hi, I can help.
  • Your gonna wire it up the same as you would a D104 as follows ---
  • 1 - White - Audio
  • 2 - Shield and Blue (Ground and Common)
  • 3 - Red -Transmit
  • 4 - N/C
  • 5 - N/C
  • Yellow - N/C
  • Black - N/C
  • Please note that any wire marked "N/C" are not used for this setup.
  • If you have any comment please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 15, 2011 | Radio Communications
I have a uniden Grant like to wire up a 4 wire D104 the mic has white black red shield
Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
  • Pin 1 - Shield - Shield
  • Pin 2 - Audio - White
  • Pin 3 - Transmit - Red
  • Pin 4 - Receive - Black
Regards, Tony
May 05, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Im trying to wire a astatic d104 m6b to a galaxy 949 mobile can you give a color code for what color wire goes were?i have black white red blue and a bare wire thank you.
This works for any mic.
dont worry about color codes. look at the switches.. there will be a common on both poles of the d104.. those need to be tied together to grnd. pin 1 on mic . the others d104 on n/c side is your rx. pin 4... the n/o one will be your tx pin 3 the other n/o will be audio and will have a wire from the mic element also on that pole of the switch. pin 2..
Sep 25, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Wiring a mic
Pin 1 is white
Shield and blue is to Shell. Guess it means ground
Pin 2 is Red
Yellow and Black no connections. Hope this helps................
Mar 25, 2009 | Magnum DeltaForce CB Radio
Cobra 18 WX ST 40-Channels Base CB Radio Logo
259 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
