Question about Garland H283 Gas Kitchen Range
DCS Mod. 60-624b62n
Both ovens will lite, but after cycling off, oven will not come back on. Thermo coupling and thermostate have been changed out. Unit was converted to propane
I am not sure of the model number of my Garland gas range (propane) I bought it in 1970 from a farmer who had purchased it at a restaurant sale. It is OLD. (so am I) I have had trouble for years with the ovens going off at times and not relighting immediately. The right oven especially.
In the last 35 years I have had the thermocouplers replaced twice, the safety valves twice, and new pilots twice. The last time these were replaced was 6 months ago by a repairman who said this was the problem. Very spendy. The ovens still would go out. I had a thought (and related it to the repairman) that perhaps there wasn't enough air circulation to the oven burners (the top burners and grill worked fine) He said there was plenty of air getting to the ovens. Two weeks later I had my son help me move the stove out another 4" from the wall and I have not had one bit of problem with the ovens since.
You can buy new fire bricks for the grill at a heating shop. I am having trouble with the thermostats now, they don't regulate the ovens to coincide with the settings. I will have them replaced next.
Every one thinks I should just get a new stove. No way. This is a great old stove, I love it.
Posted on Nov 28, 2008
  • mgilby Dec 03, 2010
    I have a Garland 284-24th/384-24th range. The right oven is fine. The top burners and the griddle are fine. The left oven worked for the first 20 years or so and now I cannot get the pilot light to stay lit. Last year the repairman changed the saftey valve. It lit and worked for a few weeks and then went out again. Do I go through the same thing again this year?
How to calibrate my DCS ovens
hi there.
this is all i could find.go to this link and see if it helps you.
How to calibrate DCS ovens Google Search
Nov 19, 2017 | DCS Ovens
DCS Double oven cooling fan will not turn off
Is this a convection oven? Need more info.
Mar 03, 2014 | DCS (WOTD-227) Double Oven
Dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Jul 19, 2009 | DCS (WOTD-227) Double Oven
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
Cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Aug 25, 2007 | Whirlpool RBS245PDS Electric Single Oven
Oven will not heat at all after an interrumpted cleaning cycle (power went off)
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Jan 02, 2007 | KitchenAid KEBC107 Electric Single Oven
Garland H283 Gas Kitchen Range Logo
324 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
