VCR tuning to TV stations
Hi rodamo
We have just moved to an area with different tv channel fequencies and have lost the instruction manual for our JVC HR-J625EA VCR machine. We've connected everything up and the videos play ok we just don't know how to retune the VCR to pick up the tv channels.
Can you help?
Regards and thanks in advance
Geoff
    Champion:
  • 224 Answers
Sorry I hadnt repied,have been away.
Once you have found that the vid plays ok on a certain channel,press stop on vid,so noyhings playing,then there must be a scan or search button on remote,its important you are on the channel that the vid plays on ,when doing it....I looked for a manual bet couldnt find one,
Rod
Posted on Sep 19, 2008
Mikomi lcd/dvd icannot program the tv to any stations
Have the same problum they say my signal board went bad and I cant find a part to get it fix the com. went bankrupt.
Sep 15, 2009 | RCA Mikomi 5290925 15 in. LCD TV
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
Need to retune Sanyo VCR VHR-610.
On the Sanyo VHR-610 you start the TV auto tune by holding down both the CHANNEL ( +, - ) buttons on the VCR simultaneously for more than 2 seconds.
The TV stations in your area will be automatically preset in order starting from programme position number "01"
When all available stations have been preset, the function will stop and the TV station preset to programme position number "01" will be tuned on your TV screen.
In other words after holding down the two buttons, leave it alone for awhile (takes some time) till it ends back at 01.
Cheers
Apr 07, 2009 | Sanyo Televison & Video
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
Tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Vcr won't record tv
You have to plug the antenna to the VCR, in the "Antenna IN" plug, from there it goes to the "TV OUT".
You use the VCR to tune the TV and choose record according to your VCR model.
Hope That Helps!
Jan 26, 2008 | Televison & Video
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
How to tune an old Television
If you are in the US, the TV set has to be on channel 3 or 4, if your in the UK, the TV would have to be on a UHF channel. It should say on the RF output of the VCR what station you must tune to ,or in the instruction book of the VCR. Good Luck
Mar 25, 2007 | Philips 26PW6341 26" TV
Open Questions:
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
