Question about Belkin Computers & Internet
Would like to password protect my home wireless network. Using Belkin N Router
  • 300 Answers
Since I didn't see the exact model listed I will give you a broad description of how it should be configured.
First, Ill give the link to find the manual for you specific model. The model can usually be found on the bottom of your product.
http://www.belkin.com/support/
You will be able to enter the model number in the Product Support Search field and then click the arrow on the right side of that field. Then verify your selection by clicking the model number again in the Select a product field. Once you have done that, you will see a list of download that may include a link for the manual, wireless security configuration information, and also software (firmware) updates for your particular model.
In the manual I would suggest looking at the security sections, especially the WEP security and the MAC address Control section. This should help you setup the router securely.
If these instructions are too broad please supply us with the model number and we can give you specific instructions.
I hope this helps. Please remember to rate this information.
Thanks
Posted on Aug 31, 2008
Changing network password
You can change your wireless encryption to protect your wireless network from unauthorized access.
Connect a LAN cable from Belkin to yourlaptop/computer's LAN port, open a browser on your laptop/computer and enterthe Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings.ie. SSID (wireless network name) WPA or WPA2 encryption key.(wireless protection).
Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 02, 2012 | Belkin Basic Wireless Router
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Click it
Aug 18, 2011 | Belkin Surf N300 Wireless N Router
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
I have loaded my PC with the SW for my F7D4302 Belkin Wireless Play Router and when I go in the other room to access my wireless laptop - the system asks for my network key and confirm key.
Hey hi dude. The router which you have installed recently in your system is password protected i guess. While installing the router software itself you will be asked to give some password in order to protect the router from 3rd party interference and to make it personalised for you. So just recollect the password which you have given that time and give the password to connect it. You can able to connect it. The problem is not with the distance between the router and your laptop.
Aug 02, 2010 | Belkin Wireless Play Router (F7D4302)
Laptop stopped connecting via wifi to home network.
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
Dec 31, 2009 | Belkin (F5D7231-4) Wireless Router
CANNOT ACCESS 192.168.1.1
and this means your question is what? Is this supposedly the default or setting you made for your Belkin?
If you didnt password protect your router, you can get access to it using Network Magic, free download and eval period, to manage all aspects of your network. http://www.purenetworks.com/nmlp/home-networking.php?gclid=CPSW0auz6p0CFcNx5Qod3SHsKg&src=google&kw=network+magic+download
Nov 01, 2009 | Belkin (F5D7231-4) Wireless Router
We have purchased a new notebook{higrade brand vista OS} to replace a packard bell using XP the XP laptop connected no problem the newone finds the belkin router but won't connect to the internet are...
Do you have a wireless security protocol enabled, and if so, what? Install a wired connection to the router (use an ehternet cable to connect your laptop's RJ-45--looks like a wide phone plug--into one of the Belkin router's network jacks). Go to the router's management page using your web browser (probably http://192.168.2.1). If you have not previously set the password in your router, simply leave the password field blank and CLICK "Submit". If you have previously password protected your Belkin router, use the known password. If you have forgotten your password... you'll need to reset your router.
Reest Router: there is usually a small hole into whiuch a pin or paper clip can be inserted for this purpose or a small button to press. Most Belkins--IIRC--have the button.
Once you are on the Belkin router's management page, look for the wireless link and set your security protocol to match what your wireless card is capable of, set the password, save and exit. Use the sasme password in configuring wireless networking in Windows.
Jul 17, 2008 | Belkin Computers & Internet
Wireless network security
alright... it does depend on the model of belkin itself but here goes... assuming you have windows since most people with mac are QUITE familiar with PCs Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page.You will get a login page. Leave the password blank. Click Submit .On the left side of the page, click Channel and SSID below Wireless . . set it to have a wireless password... (again the exacts depend on your model) by doing this a computer must have that password you made to access the connection.. now depending on you computers operating system(ie: windows 95,98,200,ME,NT,XP vista or a mac) will depend on how you put this "password" into your computer... windows- START-CONTROL PANEL-(network and internet options)NETWORK CONNECTIONS-VIEW AVAILABLE WIRELESS NETWORKS and when you try to reconnect to your internet connection you will be prompted for the password... IF however your wireless adapters have their own wireless clients then you will have to contact their tech support instead of that last paragraph heres the number to belkin tech support in case your router will not allow you into the interface 1 800 2BELKIN x2263
Jun 07, 2007 | Belkin F5D7630uk4A Wireless Router
Computers & Internet Logo
56 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
