Location of the washing machine filter smartdrive 058
  • colinharriso Jan 04, 2009
    1. where is the filter located?
  • 639 Answers
Peace Friend,
ngfam1 At your service!
Check the user manual.
You can download or order it at the companies web site
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Water leaks into my smartdrive 058 machine throught the wash cycle and when the machine is switched off.
you need a new water valve for the unit. The solenoid is getting stuck in the open position (at least partially) and allowing water to continue to come through even after the water valve is no longer energized. This can be caused by normal wear and tear or sediment from your pipes getting stuck in the valve. This is especially true if you have well water or have recently had any plumbing work done in your house like a new hot water heater or something like that installed.
Nov 16, 2012 | Fisher and Paykel Washing Machines
Dirt after washing
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 11, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel Smartdrive MW058K stops during cycle and hot and cold water temp lights flash along with progress light
This means that the machine can't get any water or enough to wash with.Check to see taps are on hoses for kinks and filters in water hoses are not blocked.
Jul 24, 2012 | Fisher and Paykel Washing Machines
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
Kelvinator Smart Drive 058 and I think the filter needs clearing
Hi there.... I don't have a solution but we have the same problem! If anyone is reading this and know the answer, you'll definitely be helping two people out!
Jan 28, 2010 | Fisher Washing Machines
My smartdrive 058 the water temperature lights up on hot, when I set to warm cold it beeps and does nothing until I press it. Why?
this is what we call a user fault : you may also hear a series of beeps as well usaly idicates hot water is not detected this may occur when warm or hot is selected solution make sure hot water is avalible to machine
Jan 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a smartdrive there is no power to the board
hello mam please check the mains cord and the loose connections inside the machine.
Oct 04, 2009 | Washing Machines
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
