SOURCE: Heating Problem w/2000 Plymouth Breeze.
Sounds exactly like what my mom's car was doing as for the blower only working on high. It was the resistor... I assumed it was the climate controls and replaced them but it didn't change anything then i thought that i must be the blower motor and replaced that too but it turned out to be the resistor which is under the dash on the passenger side of the car.
SOURCE: PLYMOUTH BREEZE 99 WILL NOT BLOW HEAT UNLESS ITS ON HIGH
It's your blower motor resistor that's shot. I just replaced mine. It cost $40 canadian and I replaced it in 10 minutes. It's located under the glove compartment. Just remove the blower cover (2 push pins) and there it is under the blower.
SOURCE: Replacing the heater core on a '88 Plymouth Sundance?
Behind the dash. You will have to pull the whole dash assembly. It looks like a little radiator.
SOURCE: 1989 plymouth sundance obd1 code 11 car dies when
The code 11 is referring to your coil pickup.This is located under the distributor cap and rotor,and is held in by the distributor cap itself.Being electrical when it gets hot the sensor brakes down .The pickup is not very expensive at all:)
SOURCE: how to fix emergency brake on 1991 plymouth
There is a wire split under the car on driver side,but follow the wire and you should run into the prob.
Have you checked rad fan relay, usually located on drivers side near shock tower.?
