Question about Nikon F100 35mm SLR Camera
Film The film did not automaticly rewind? How do I remove the film
Have you tried pushing the BKT and +/- buttons together? You can change the custom menu to auto rewind at end of film - CSM 1 : 1
Posted on Sep 29, 2008
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Aug 23, 2010 | Nikon F65 35mm SLR Camera
How do u get the camera 2 rewind
Usually the automatic rewind starts when the film roll has come to the end. You can rewind also before that by a rewinding button you'll find usually somewhere in the camera body.
To rewind manually, press the film release button (consult the manual if you don't find it) and use the rewinding lever to rewind the film. See this for inspiration: http://www.ehow.com/how_2028878_film-mm-manual-slr-camera.html
Jun 19, 2010 | Nikon Photography
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Feb 21, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Nikon F100 35mm SLR Camera Logo
147 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
