Require tv codes for use with Motorola sat receiver 301
  • ve3mhm Aug 31, 2008
    I no longer require assistance. I got the manual from a friend which gives me the TV codes for use with my Motorola Sat receiver, model 301
Please cancel inquiry into above problem
Posted on Aug 31, 2008
Can you please provide more information to allow us to further assist you, for example could you please let us know the manufacturer of your universal remote? Also just to confirm, are you trying to program the remote to your television, or are you trying to program the remote to your 301 receiver? Or is it both? In addition, you may also be able to contact the manufacturer of your universal remote if you'd like and they can also provide further assistance in regards to the remote codes you are requesting for the remote if they are not included in the instruction manual that came with the remote.
-Kirstie DISH Network
Sep 09, 2010 | DISH Network 301 DTV Receiver
Does the dish network 322 receiver require two lines from the satellite to the receiver?
It does require 2 lines form dish unless you have a switch installed such as a dp34 or you have Dish Pro plus LNB"S on your dish and you can use 1 feed to the reciver and use a separator to separate the signal into sat 1 and sat 2 (note: a standard splitter is NOT a separator) a separator is dish brand equipment.
Oct 15, 2009 | DISH Network 322 DTV Receiver
I neet to program a dish network universal remote to my ccd tv. how do i do it?
To program the remote to your TV we would need the model # on the back of the remote at the top. To do it yourself you can check out the link provided below to get the codes for TV manufacturers, DVD's, amplifiers, etc.
To program the remote to the TV
1. Turn TV on.
2. Hold TV button on top of remote until all the mode lights turn on.
3. Let go and the TV button will blink. Enter the code found at link below and hit #.
4. Try the use the remote, if it works then push SAT and you're good to go. If not repeat steps 2 and 3 to try a different code.
Link for Codes
Tommy Faust
DISH Network
Oct 12, 2009 | DISH Network 301 DTV Receiver
Dish Network - Loss of signal after smart card upgrade.
Hi I will be more than glad to assist you in this concern.. Since you did already all the troubleshooting to fix the problem and according to the customer service, just run the check switch and test, that should fix the problem, but it didnt. The blue card that your refering is the g3 smartcard, it started when u insert to the 301 receiver.. It could be a bad smartcard or the receiver is bad, If you have another solo receiver in the house, just to isolate the problem, try to hook up the other solo receiver in the room where the 301 receiver is hook, run a check switch and test to the other solo receiver, once its done check your sat and signal, once its ok, cancel all the way out and it should acquire the sat will show attention 015 and let it finish the progress until it download the programming guide.. once u got a picture and the problem still exist with a different receiver. the problem is with the receiver and the receiver needs to be replace, if you call on dish network tech support, tell them that you try using another receiver and install to the room were the 301 is located, so that they wont do a troubleshooting again.. that is.. if you have another receiver to test and isolate the problem, but if not request for a service call so that they will send tech to your house.. please feel free to get in touch.
Sep 04, 2009 | DISH Network 322 DTV Receiver
I have URC-5741B00 and need to get the code for a Panasonic 27" TV and my Motorola Moxi Cable box. It might be too old for these codes.
for the tv these codes might work..
0171, 0170, 0148, 0054, 0062, 0374, 0381, 0437, 0950, 0003, 0070.
Hopefully this will help
Aug 20, 2009 | One For All Televison & Video
Have a 322 with a DP 34 switch and have a strange problem. I thought something may have been damaged in a recent storm, TV 2 lost signal entirely and I lost sat 110 on TV 1 leaving me only 119. After some...
bring the 301 receiver to where the 322 is and one at a time hook each satellite in coaxial feeds to it if you get both satellites then the receiver can be the problem if not then the outputs on your dp34 switch can be defective.
Aug 10, 2009 | DISH Network 322 DTV Receiver
I need to program my new dishnet work remote
Turn the receiver off using the front panel power button and then press the channel up button and hold it until the unit powers on. This will bring you to the system info screen. There you will see the remote address the remote needs to be programmed to- usually 1. Now press and hold the SAT button on top of the remote until all buttons on the top lite up and release. Now key in the two digit number shown on the screen - numbers under ten will be preceeded buy a zero. Now press the pound sign on the bottom right of the keypad. The SAT button will flash three times and then you will need to press the record button . YOU SHOULD BE ABLE TO MANUEVER THE HIGHLIGHT ON THE SCREEN AND EXIT OUT OF THE SCREENS . Thanks for using Fix Ya. ---and if you can not bring up the system info screen perform the steps on the remote itself until you reach the correct number that will control the receiver- 01 thru 16. if you need further assistance please let me know.
Mar 28, 2009 | DISH Network 301 DTV Receiver
Toshiba dr-2 and directv hd sat rcvr hr22
Check the manual to see if there is an automatic code search feature for your Toshiba. It may be easier to program your directv remote to operate your toshiba. You may not get the full use from either remote, but its worth a shot
Dec 01, 2008 | Arris DCT2608
Want to use my old dish set top as dtv tuner
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Nov 16, 2008 | DISH Network 301 DTV Receiver
Televison & Video Logo
Top Televison & Video Experts
