Question about Cameras
Kalimar exposure meter
I have a model # 8 FQ clip on but can't find it anywhere. Do you know about this model and how old it is?
How can i get my kalimar auto zoom lens fit my canon eos 650
Don't know but I just bought a kalimar 135mm f2.8 lens on eBay and it has a threaded mount that is not T mount and is not M42 mount? I am hoping there is an adapter somewhere out there as it seems like a very well made Japanese lens! If you figure it out let me know?
Feb 09, 2013 | Kalimar Mc Auto Zoom Macro 1:4 - 5.6...
Kalimar 500mm lens
With the proper T-mount adapter this lens will fit just about any camera, film or digital, with an interchangeable lens. However you will not get autofocus, and most likely will lose the camera's autoexposure capabilities as well.
Sep 02, 2012 | Kalimar 500mm F/8 T-mount Case
I have a Kalimar tripod model PE-8, it is missing one of the the feet on the bottom of one leg. I can't release the leg without this part.
I have the same model, purchased from a pawn shop with a foot missing. My husband replaced it with a pencil eraser. He put shrink tubing material around the eraser until it was the right size to screw on to the thread. I hope this helps.
May 19, 2010 | Kalimar V-20S VIDEO TRIPOD
Useing a weston master2 exposure metre
They're lovely old light meters and there's an online copy of the manual for your exact model at the address below:-
Have fun, and please return the favour by rating my answer.
Apr 20, 2009 | Cameras
Aunt's 1930-1940 Kalimar 45mm fixed F/2.8 with a screwy shutter
I have an close family member that has one he is willing to sell. The camera is in great working order.
Dec 27, 2007 | Photography
Ex & Built-in Flash
You need to do what is called an exposure lock. Aim at the subject, even if it's out of focus and half press your shutter. Then press the * button on the camera (top right) and it will exposure lock. You can then re-focus, but it will hold the exposure that was metered previously, so you'll get focus on a different object to what the camera has focused on. You can exposure lock anywhere, it doesn't even have to be your subject, it could be a nearby window to underexpose, or a nearby dark area to underexpose. Once you've locked the exposure you can focus somewhere else.
Dec 04, 2007 | Canon EOS 30D Digital Camera with 18-55mm...
Kalimar LX-7 Google: Knows all, tells all!
Sep 22, 2007 | Photography
Kalimar pe-8 tripod
It is a standered size and thread found on all cameras. Ace is the place
Dec 01, 2006 | Kalimar V-20S VIDEO TRIPOD
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Cameras Logo
160 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
