I have a Samsung DC68-02683A washing machine. It was working perfectly fine earlier and now will not turn on - there is no power. I unplugged it and left it off for upwards of an hour. It will not power on whatsoever. No lights, no nothin' - and because of this, it will not open the door so my blanket is stuck in the machine! I don't believe it ever went through a cycle, either. Help please!
200 people viewed this problem
Hi
Check the power supply/fuse in the first place. If the supply is right then the problem is of the door. Try to push the door a bit hard and try to open the door. When the machine is switched off the door has to open, find out if it is not stuck. Finally if things dont go your way call a mechanic.
Regards.
PLZ. dont forget to rate my suggestion.
Christine Waters Thanks! We turned off the power at the circuit. The dryer is on the same outlet and it's fine. And I don't believe it's just the door, because the machine will not turn on at all. I think I'm going to have to call a mechanic which is what I'm really wishing I didn't have to do. :( Thanks for your response.
Jul 27, 2011
denise_lucke Christine, I'm having the same problem. Any luck diagnosing?
Dec 15, 2012
I get 3 short beeps when I press the 'Power' button. Power does not come on (it's plugged in and there's power to the...
The washer will not work is there some kind of reset button to re program the washer or do you have a detailed...
cannot use machine due to f11 fault on dyson cro1
My machine is now approx 4-5yrs old (Model MW511). It was working perfectly until i just moved house. Now as soon as it...
I have a ge front load washer model number WBVH5100HWW . When you set any cycle it fills with water and immediately...
I have a Kenmore washer midel # 429221416 the belt came off got bavk on but it keep coming off any suggestion
